Sponsored by: Auxito
no spark
Old Jul 6, 2005 | 02:20 PM
ord problem's Avatar
ord problem
no spark
hello every one my name is bill i have a 98 f150 i am having trouble i lost fuel and r/r fuel pump now i lost all spark i r/r coil pack r/r crank senior still have no spark can anyone give me help thank you.
Old Jul 6, 2005 | 02:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Jul 6, 2005 | 09:06 PM
projectSHO89's Avatar
projectSHO89
Assuming a V6...
This is from the 97 EVTM, don't have a 98. Hope the circuits are the same.
Check the R/LG wire at the coil connector (START or RUN).
No voltage, suspect F30 in the underhood fusebox or the ignition switch.
If battery voltage is present, check fuse F1, small fusebox on inside fenderwell. It supplies operating power to the PCM.
Steve
