2009-2010 thread
Old Jan 24, 2014 | 02:47 PM
  #31
Torklift Sheryl's Avatar
Torklift Sheryl
SPONSOR
Originally Posted by D8chumley
Here it is
Originally Posted by Robbgt
HAHA! Torklift stable load should help out here
They are StableLoads not StableMinds..might need some extra help on this one
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old Jan 24, 2014 | 04:33 PM
  #32
derek4343's Avatar
derek4343
I don't have them but have read plenty good from the guys that do. I'd guess its the price? LK you can do for what, $80? I looked up the 5100 with 2.0" adjustment and they're a little over $100 ea. I'd do them if I need front shocks and ditch the LK but when I did my LK I only had ~ 3K on the truck
I did order the bilsteins all 4. Autoanything. Chat guy knocked off another 10 0/0. $308 delivered. Not bad I guess
Old Jan 24, 2014 | 04:53 PM
  #33
D8chumley's Avatar
D8chumley
Resident smarta$$
👍👍👍 Let us know how you like them
Old Jan 24, 2014 | 08:22 PM
  #34
SWV10's Avatar
SWV10
Good info here.
With the Trans Temp Gauge in the 09+F150, what is the temp reading in degrees at the Yellow mark?
The following is what I observed with my then 07 F150.
My concern comes from overheating my Tranny with my 07 F150 SC 5.4L 3:73's/4x4 w/Trailer towing pkg. The 07 pulled the smaller tow hauler with ease, I did use a WDH/sway-bar control/trailer brakes. The Trailer at the most came in at 5500 lbs wet/loaded.
My Towing was all in the Mountains from 6500ft starting elevation to 10,000ft. 90% was on payment with the other pulling at less than 15mph on graded Forest Service roads, no more than 10 miles of a winding FS Road to the campsite.
I did this for 2yrs w/the 07 before someone asked me what my Tranny temps were at during towing. I had no answer, so since that was bought up I decided to install a digital Temp transmission gauge, I was shocked by the readings, when I got home I took it into Ford and had the trans oil change, it was dark brown after just 22,000 miles. It did not smell burnt but if I hadn't installed the temp gauge I would of never known of a problem till it was too late. The Dealer/Ford checked the stock transmission cooler and it was working correctly. With the Dealers input, a additional aux Trans cooler w/fan was installed, a B&M 7" trans cooler, the fan would kick on at 175 Degrees/off at 144.
The trans Max temps were 340F degrees with the Ford Transmission cooler with a avg of 300F while towing up and through the Mountains.
After the B&M Fan assist cooler was installed the temps never went over 205F and the 205F reading was at the very end of where I was setting up camp, the avg temp stayed at 192F.
So this brings me back to my current '10 F150, it too has the factory towing pkg/trans cooler and I am pulling the exact Toy Hauler as before.
I decided it would be best to go ahead and Monitor the Trans temp with a Edge CTS Insight but any true towing w/my toyhauler is 3-4 months away, in the meantime I will observe what the Temps read w/o towing.
I havebeen told that Today's Trannies are built very well and can take allot of abuse but what these trucks cost these days I rather know up front exactly what my Trans temps are at, plus I can Monitor just about anything else as well with the Edge Insight.
The Trans cooler in the 09+F150s is completely different set-up than what my 07 had, is located for way better air-flow as well but doesn't seem to be very big for a trans cooler. My other Fords were Superduties and the trans coolers on those 4 were never a issue.
Has anyone else been monitoring your Trans temps with the +09 F150s with a aftermarket gauge, either a programmer, Bullydog Watchdog or the Edge products?
Old Jan 24, 2014 | 09:24 PM
  #35
meborder's Avatar
meborder
SWV10
The 6r80 can run up to 220 without worries, but is considered the upper end of the "normal" range. the yellow range should be 230, and red would be 240.
this is as close to the horses mouth as you are going to get:
https://www.ford-trucks.com/forums/1...l#post13197128
Old Jan 24, 2014 | 11:40 PM
  #36
SWV10's Avatar
SWV10
Originally Posted by meborder
SWV10
Thanks meborder,
Exactly the info I was needing.
Old Jan 28, 2014 | 07:36 PM
  #37
derek4343's Avatar
derek4343
color of truck
since i have a 09 truck and my color is stone green...i was wondering did anyone else have this color? i'll be damned if it looks green. more like earth brown dirt. i don't mind it though. it doesn't seem that common. i think they only made it a couple of years.
Old Jan 28, 2014 | 07:39 PM
  #38
D8chumley's Avatar
D8chumley
Resident smarta$$
Mine is Royal Red, maroon-like. Not a lot of that color either. They didn't continue it in 2011 afaik
Old Feb 15, 2014 | 08:22 PM
  #39
seventyseven250's Avatar
seventyseven250
This may or may not be the right place for this question. Looks like I'll be picking up a newer truck in a couple of months. Possibly a 2010. For a 2010, what options would you say are "must have" to you?
Did they offer the integrated trailer brake controller on these years? I tow maybe six or eight times a year, but I'll need some kind of trailer brakes. Running a tekonsha prodigy P2 right now, and very happy with it. I hear the Ford one is great.
Looking for a backup camera for sure.
Thoughts?
Old Feb 16, 2014 | 07:56 AM
  #40
derek4343's Avatar
derek4343
sent the bilsteins back. ruined my upper control arm trying to get it off. had to cut it off after that then replace with a new one. i didn't want to repeat it on the other side so i said the hell with it. ran out of patience.
Old Feb 22, 2014 | 03:29 PM
  #41
D8chumley's Avatar
D8chumley
Resident smarta$$
I haven't heard of anyone else having problems with the Bilsteins. I wonder what happened that you had issues while others haven't? Sorry to hear of your troubles
Old Feb 22, 2014 | 05:51 PM
  #42
Tim 79 F150's Avatar
Tim 79 F150
2009 extended cab XLT 4.6, I pull a 5000lb trailer a few times a year. Factory brake controller installed 2nd year. The Factory brake controller will not work in my new 2014, they changed the design in 2011 I think. This truck has 175,000 miles - 290,000 KM up here in Canada. Does not burn any oil in between oil changes. Great ride love this truck.
Old Feb 22, 2014 | 09:05 PM
  #43
jsell30's Avatar
jsell30
I just purchased a loaded Lariat with the 5.4. This sucker has some get up but i am getting less MPG than the 5.4 I had in my 07 lariat. Any insight?
Old Feb 22, 2014 | 09:28 PM
  #44
D8chumley's Avatar
D8chumley
Resident smarta$$
Keep your foot out of it?
Old Feb 22, 2014 | 09:54 PM
  #45
jsell30's Avatar
jsell30
I drive the same as I did with my other lariat. the 07 even had a sputter.
