Torque Pro screenshots
Old Jan 21, 2014 | 02:31 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by Money-Pit
Thanks for the heads up guys. I will replace the two worthless mpg gauges with MAP and BARO and report back. What would low ebp indicate?
plugged tube. dirty/faulty sensor. the three should read within .5-1.5 psi of each other at KOEO.
Old Jan 21, 2014 | 04:58 PM
Money-Pit's Avatar
Money-Pit
Here we go....both MAP & EBP are way low. This is koeo. How do I fix this? Thanks!
Old Jan 21, 2014 | 05:12 PM
npccpartsman
The Baro is perfectly normal but with both MAP and EBP reading so close that's almost like a PID thing. Is there a way to change the PID values or more than one value that you can use?
Old Jan 21, 2014 | 05:52 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe double check with another device to verify. Or maybe a Torque Pro guru might see this thread.
Old Jan 21, 2014 | 08:40 PM
Money-Pit's Avatar
Money-Pit
What are the formulas for ebp & map for the Scangauge? I can use it to verify.
Old Jan 22, 2014 | 04:55 AM
Rusty Axlerod
EBP
Exhaust Back Pressure
07E0221445
046285140645
3010
001D00500000
EBP
Yea, MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
Manifold Absolute Pressure
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Old Jan 22, 2014 | 10:45 AM
Money-Pit's Avatar
Money-Pit
Thanks Rusty.
Anyone considering one of these, I have my Samsung tab3 7" tablet with Otterbox case mounted to the windshield with a Ram Mount Tablet holder that I bought from Amazon. The mount is rock solid.
Amazon.com : RAM Mount Twist Lock Suction Cup Base w/Universal X-Grip II : Touch Screen Tablet Computer Stands : Computers & Accessories Amazon.com : RAM Mount Twist Lock Suction Cup Base w/Universal X-Grip II : Touch Screen Tablet Computer Stands : Computers & Accessories
Old Feb 1, 2014 | 11:59 AM
Money-Pit's Avatar
Money-Pit
I haven't programed the SG for ebp or map yet.
Does anyone else have this problem....initial start, Torque Pro works great and all gauges work. I stop at the store, turn off truck, come back and restart and I get this.....it happens everytime.
Old Feb 2, 2014 | 11:10 AM
Money-Pit's Avatar
Money-Pit
OK, I just checked my MAP & EBP with the Scangauge. I got....
MAP 14.7
EBP 15.0
So I'm good. Apparently the formula in Torque Pro needs tweaked.
Yoteman
Apr 14, 2018 11:44 AM
BleackBeast
Aug 25, 2017 10:25 PM
TruckingBill
Aug 24, 2014 08:06 PM
arkredneck
Jan 18, 2014 07:35 AM
mlytc
Dec 3, 2013 07:13 AM
