Sponsored by: Auxito
Error codes out the wazoo!!!
Old Jan 20, 2014 | 02:03 PM
torranosaurus's Avatar
torranosaurus
1999 F150 2wd auto:
Error codes came up:
PO141
303
401
302
133
WITHOUT REPLACING EVERYTHING, ANY IDEAS WHAT I CAN START WITH?
Old Jan 20, 2014 | 11:46 PM
Bluegrass 7's Avatar
Bluegrass 7
Ever think of looking up the codes to see what they are telling you for information?
Codes 133/141 is ox sensor 1 on passenger side.
Look at the harness for being burnt or shorted against the exhaust.
Check fuse #23.
Codes 302/303 are cylinders 2 and 3 misfires.
Code 401 is an EGR flow failure test code. This hardware is located on the driver side.
All seemingly unrelated unless there is something else that ties them together we don't know about, at this time.
This is why you don't replace parts trying to get lucky. It costs to much money for very little result.
Go getum.
Good luck.
Old Jan 23, 2014 | 08:42 PM
torranosaurus
Thanks, I looked up the codes but wasn't sure if the truck has an upstream and downstream sensor. It is -8 out there so I am just researching right now.
I figure a set of plugs and wires may fix the cylinder misfire problem.
ol_red92
Mar 3, 2014 11:43 AM
iateatoad
13
Dec 8, 2012 10:35 PM
marragtop
Mar 18, 2008 09:54 AM
bocefusss
1978 - 1996 Big Bronco
Jun 6, 2007 04:09 PM
Rag58
1983 - 2012 Ranger & B-Series
Aug 6, 2006 08:45 PM
