2002 Explorer rear end howl.
Old 01-20-2014, 01:02 PM
compaddict's Avatar
compaddict
compaddict is offline
It's been howling for ten years. Constant. It's been inspected twice in that time and no damage is seen.
It's getting worse. Should I bring it to a specialty shop and have them rebuild it?
TIA,
Vince
Old 01-20-2014, 03:23 PM
seagull369's Avatar
seagull369
seagull369 is offline
Have you checked the fluid level? If it's OK, you might want to change it.
Old 01-20-2014, 05:20 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,667 Likes on 1,360 Posts
Bad bearings won't howl for 10 years unless you only drive 500 miles per year.
More likely it is the ring and pinion. It is unusual for a factory diff to howl due to poor ring and pinion set up. Not impossible, but search the threads, it just does not come up. Bearings yes, as there were lots of those issues in rigid axles and IRS.
If it is getting worse, you can get it redone. R&P, bearings, labor, expect north of $1000.
Beware cheap or inexperienced jobs, as you'll have a howler again in short order.
Old 01-20-2014, 09:37 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
The 2002 with 4 x 4 has an independant rear axle. The pumpkin is mounted to the truck body under the rear seat. Mine had the small howl for 10 years also. I think its the gear set mesh and the resonant frequency with the body mount. REcently it has started to get louder and i checked to see that the pinion bearing is starting to get excess clearance. I also think a good rebuild and proper gear setup would help a bunch.
Old 01-20-2014, 10:49 PM
compaddict's Avatar
compaddict
Yep. It lasted this long. About time for a fix.
Old 02-21-2014, 05:34 PM
compaddict's Avatar
compaddict
It was the rear wheel bearings! Damn.
Old 03-12-2014, 01:24 AM
weross67's Avatar
weross67
weross67 is offline
Exclamation Great News
I have been looking for a solution for this problem beginning in 2002 I found it on 3/10/2014. Ford makes a kit to correct this problem amazing consisting of Pinion bearings front and rear, seals, large and small pinion gears and a shim set for the pinion gears there is several other smaller items also. There is a TSB covering this it is TSB 05-23-3. I have replaced the axle bearings on several trucks with little results in noise reduction.
Old 03-18-2014, 05:23 AM
RedTaurus94's Avatar
RedTaurus94
RedTaurus94 is offline
Mine was caused by the wheel bearing. After I had it changed, no more noise....so far.
the_auto_tech
2009 - 2014 F150
08-26-2017 12:49 PM
f1001969mike
1978 - 1996 Big Bronco
09-08-2013 10:55 PM
devozoo
1997 - 2003 F150
16
02-01-2011 05:58 PM
thegreenmachine
1999 to 2016 Super Duty
06-02-2010 06:33 AM
9explorer8
05-31-2006 01:41 PM
Quick Reply: 2002 Explorer rear end howl.
