Differential gear question
Old Jan 25, 2014 | 10:35 AM
  #31
Sw1tchfoot's Avatar
Sw1tchfoot
You can always go to Pick-N-Pull and see if they have any 1980-1986 Ford trucks to pull a third member from. It just needs to be 31 spline and it will bolt in. I picked up a 3.25 unit but never installed it.
Old Feb 3, 2014 | 05:23 AM
  #32
RadioControlGuy85's Avatar
RadioControlGuy85
is there a way to figure out what ratios are in the transmission?
factory saids there 1st2.99 2nd1.75 3rd1.00
Old Feb 3, 2014 | 05:40 PM
  #33
Franklin2's Avatar
Franklin2
If you have the tranny laying there, mark the input and output shafts and then count how many times the input shaft turns to get the output shaft to turn 1 turn. You can do a google search also. There is a thread on here now where someone posted some of the different trannies.
Old Feb 3, 2014 | 06:49 PM
  #34
RadioControlGuy85
i have been looking all day.havent came up with nothing.
must be looking up the wrong stuff
Old Feb 4, 2014 | 01:49 PM
  #35
1986F150six's Avatar
1986F150six
The FORDification.com Forums • View topic - Transmission gearing and info! Save INFO!
Give credit to Ken Blythen for providing this link to me on another thread.
Old Feb 4, 2014 | 05:41 PM
  #36
RadioControlGuy85
thanks for the info.but im trying to figure out a way to see if the gears are factory.or if there not.
guy we bought the truck from said they did work to the rearend or transmission for highway use.
Old Feb 4, 2014 | 05:53 PM
  #37
Franklin2's Avatar
Franklin2
I doubt they modified the tranny. If they did anything they changed the rearend out. You can easily check that the same way. Turn BOTH tires at the same time, one turn, and see how many times the input shaft where the driveshaft hooks to turns.
Old Feb 4, 2014 | 06:03 PM
  #38
RadioControlGuy85
we have done checked the rear end.and its has the factory gears in. thats why we want to check the transmission or find a way to check the trany
Old Feb 5, 2014 | 10:50 AM
  #39
1986F150six
Since you have confirmed the rear ratios, simply drive the vehicle with a tachometer hooked up. Record the RPMs at several different speeds in high gear and then, using one of the online gear calculators, see if the RPMs being turned match up with the correct speed [kind of backwards, but should work].
Make sure you correct for oversized tires, if applicable.
RGPolo
Jul 3, 2018 05:39 PM
niteowl
Oct 29, 2013 12:50 PM
stevejr
Mar 7, 2004 01:54 PM
harddrive4x4
Nov 29, 2003 03:26 PM
jwtaylor
Oct 2, 2001 04:15 PM
