WHo all have removed their Cab Vents
Just curious how many people have removed and blocked off the cab vents in the rear wall of their truck when doing stereo upgrades and why?
I have done a bunch of research and the popular consensus is they should not be blocked off as they are there to
1: equalize pressure when the doors are shut making it easier to close the doors and not make your ears pop. There is the leave a window down a bit but I am not into windows open at -30 or so assuming you can even get them open.
2: Make life easier for the A/C and heater blower motor because without the vents the fan would pressurize the interior and have difficulty moving air.
3: Safety, to prevent an issue with your ear drums should the air bags deploy.
So what are your thoughts on this? I am going to come up with a way to keep mine useable when I install my amps and JL AUdio Cleansweep and SSI units and the new sub enclosure.
The main reason these get covered up is for the installation of a subwoofer box behind the seat because they stick out from the wall of the truck to where the sub box doesn't fit. Usually depending on the configuration of the sub box only one gets covered. Your concerns about covering them are valid, however I've never heard the one about the air bags. If you do decide to add a sub I suggest getting one that leaves one of the vents open.
I have read about this with every brand of truck out there and one would assume that if these were not needed the manufacturers would eliminate them in a heartbeat to save some $$ like they get rid of other stuff like the courtesy lights in doors.
I am hoping I can fit the .9cf sub enclosure I bought in without too much difficulty as it fits in the space the original sub enclosure was sitting and as a worse case having to remove the passenger side one. I will work around the driver side one when I make the component mounting board.
I have to say though I have not removed the rear wall cover yet to see just what I am up against.
Lifted94XLT
21
09-16-2020 09:58 PM
Midnite1987
04-10-2015 10:32 AM
kereams
6.7L Power Stroke Diesel
01-11-2012 10:26 PM
Peach
09-04-2005 01:50 AM
