Converting to electronic ignition
Old Jan 21, 2014 | 10:16 PM
tyrantsparky's Avatar
tyrantsparky
Dang, I was hoping to convert but it may not be an option. If I change my distributor, will it then be possible. Of course I would then need to change that holley 1904 I have on there.
Old Jan 21, 2014 | 10:44 PM
rustywheel68's Avatar
rustywheel68
why can't you install the Pertronix?
or were you specifically wanting to switch to Duraspark?
Old Jan 22, 2014 | 06:22 AM
tyrantsparky
Would the Pertronix work with the stock distributor? I think it is the spark o matic. The holley has a spark control valve.
Old Jan 22, 2014 | 06:31 AM
charliemccraney's Avatar
charliemccraney
223 cancelled at the end of the 1964 model run.
DuraSpark Electronic Ignition introduced in 1974, but not all vehicles came with it until 1976.
All FoMoCo vehicles w/DuraSpark: 1974 module is 1974 only; 1975 module is 1975 only.
I meant an aftermarket conversion, of course. My 292 didn't come with it either, but the distributor has been converted to Duraspark components.
Old Jan 22, 2014 | 06:40 AM
rustywheel68
Summit Racing shows a Pertronix part # for your engine, yes.
All you're doing is replacing the points, so the spark control valve mess doesn't matter.
Pertronix I
http://www.summitracing.com/parts/pn...l/f-100-pickup
Pertronix II
rsh1966
Jan 31, 2017 04:52 PM
f-250.4x4.390
Oct 16, 2015 08:21 PM
73FordF100
15
Jan 25, 2012 01:44 PM
LARIAT 85
Nov 16, 2006 06:30 AM
f100guy
Oct 5, 2003 12:21 PM
