Finally have a gallery ( Jim VA.)
Very nice Jim. I really like the dash/interior paint scheme.My dash is allready painted---but.Tell me more about the rear suspension.I have mine set up with the original Dana 3.92, when I started this project it seemed ok with auto o.d. I may need to go to something like yours.Is that rear about 63" drum face to drum face?Great job Jim.
Fenders; I think it is the same as your's only not painted.I did not have the cash to buy a Banjo. Do you still have the template for the tailgate hooks?I am almost at that point where I will need it. The dash insert is from Carpenders,it comes as a rough finish cast aluminum.so why not sand and paint ?Speaking of paint the photos are off on the" Purple" on the chassis. I found a 2000 Z28 ten bolt locker with 342 gears and 12" discs with only 1500 miles on it. The only thing wrong with it was a bent pass. side axle.which I bought new at local GM dealer for less than $96.00 .Joe;The 59 1/4" is from outside of axle flange"s I washed off all "coil over"stuff. reversed the calaipers from rear to front,relocated E-brake cable mounts,installed new perches to fit new 8 leaf stock springs after figuring the correct pinion angle. I did not "C" notch the chassis,I still have 1 3/4" between the bump stop and axle hsg. I don't plan on hauling anything but A-- . Had to go to 16"X8" rear rims to clear the calaipers.and have P265-50R-16 BF Goodrich radial t/a . There is 1 1/2" clearance on outside and 1 3/4"on the inside between the fender and the bed side with this rear and tires. keep in mind I am using 3" wider "glass" fenders. Adapted E-brake cables to the stock rachett in the cab,works great. Jim VA.
Purple.... Pink.... Same difference, we're keeping a close eye on a couple of you guys.
Yes I made the template for the gate hooks. Send me your address again and I promise to mail it out right away. Sorry about that Jim.
And that reminds me.... Paul, did you ever receive the gate hooks I sent? I hope so because I know I mailed them a month ago.
Originally posted by himmelberg
"you cant make art and be afraid of color"... this is a quote of self. I like it. Call it what you will. Manly men are not afraid of color. Best. Himmelberg
