Compression Test Question
Old Jan 18, 2014 | 08:45 PM
TKegs763's Avatar
TKegs763
Heading up to Harbor Freight tomorrow to buy a compression test kit and finally calm my nerves. I have never done a compression test before, so I was wondering if you guys can walk me through this or give me some advice?
Old Jan 18, 2014 | 08:56 PM
Mowing Man's Avatar
Mowing Man
Disconnect 42 pin connecter, pull VC. Pull all GP's. Crank engine over a few times with VC resting on to blow out excess oil that went into GP holes. Thread fitting in carefully (Harbor Freight fitting cross threads easily) crank it over with gauge hooked up, probably 5-6 revolutions. Take the reading, release the pressure, repeat on next cylinder. You'll probably have to put your batteries on the charger while this is going on. You have to have good RPMs for an accurate read. We got between 340-380 on a 7.3 with 362k last week, and around 400 on another one with 80k miles. On the high miles engine, I had to pour a tablespoon or two if oil down the GP hole, but the engine had sat a while, low on oil with several oil leaks. They read 0 at first, til I poured the oil in, blew it back out and then took the readings. Good luck.
Old Jan 18, 2014 | 09:29 PM
TKegs763's Avatar
TKegs763
Thank you Mowing Man! It is ok to turn over with the key? I'm at 333,000 right now and just need to be sure. My turbo is done and the injectors are original. But before I go and blast my Buck$zooka I need to make sure it's even worth it.
Old Jan 19, 2014 | 12:20 PM
TKegs763's Avatar
TKegs763
At what temp does the truck need to be? Cold or warm? Pulling the valve covers off now. Thanks again!
Old Jan 19, 2014 | 01:28 PM
Dan V's Avatar
Dan V
If you use the key, without unplugging the 42 pin connector, the injectors are going to inject fuel. And the fuel pump is going to run.
IMO...just best to jump the solenoid.
Old Jan 19, 2014 | 01:39 PM
jetdoc's Avatar
jetdoc
I had read that the Harbor Freight kit did not work on our trucks....You had to get a special fitting to adapt.
Old Jan 19, 2014 | 02:59 PM
Pikachu's Avatar
Pikachu
The one in the HF kit doesn't fit, but Mityvac has an adaptor that fits in the glow plug port. However the quick connect fitting doesn't work with the compression gauge from HF. I took my Mityvac adapter to a hydraulic shop and had them cut off the male quick connect fitting and put a 1/8" NPT fitting on it instead. Then I just removed the schrader valve from one of the extra fittings in the HF kit and threaded it in. It was less than $5.00 to have the fitting changed. The Mityvac part number for their adapter is MVA5605.
Old Jan 19, 2014 | 03:17 PM
TKegs763's Avatar
TKegs763
Yeah, I read up on the HF this morning before I headed out and just decided to get a good kit from NAPA in case someone around here might need a test in the future. That one needs an adapter too!!! Just going to cruise junk yard row tomorrow and find the snap on or Mac tool truck to snag the adapter. I hope all of this gives me good karma to the engine compression gods..
Some of the pins in my 42 pin connector look corroded a little bit. Is that normal?? Also my turbo blade is NASTY!! Wanna see some pictures ?
Old Jan 19, 2014 | 03:27 PM
jetdoc's Avatar
jetdoc
Im literally running out the door, late for work...Search for BigAlsPSD compression test write up....It will save you a TON of cash...
Old Jan 19, 2014 | 03:33 PM
Pikachu's Avatar
Pikachu
I noticed a very small amount in mine as well.
Of course we wanna see pictures (duh)!
Old Jan 19, 2014 | 03:44 PM
TKegs763's Avatar
TKegs763
Haha! Here ya go!
Old Jan 19, 2014 | 03:49 PM
Pikachu's Avatar
Pikachu
Neither of those look too bad to me. My connector didn't have quite that much corrosion, but it's a Southern truck (FL and TX). But on my old compressor wheel it isn't even obvious that it ever had corners! The early '99 filter housings were pure trash.
EDIT: I see you're in Arlington. How has the weather been down there while I've been stuck here in CT?
Old Jan 19, 2014 | 03:50 PM
HKusp's Avatar
HKusp
Yeah, that wheel is not good. Time or a new one. The 42 pin looks okay. Spray some electrical connector cleaner and maybe some di-electric grease. You'll be fine.
Old Jan 19, 2014 | 03:57 PM
TKegs763's Avatar
TKegs763
It's been in the mid 30's at night and almost 70 during the day, consistently. I just plan on putting in a new turbo, sticks, HPOP, glow plugs, frx, and tuner once I find out if my compression is ok. There is no more waiting and this needs to be done like yesterday. Truck runs terrible!
Old Jan 19, 2014 | 03:59 PM
TKegs763's Avatar
TKegs763
Ok I will do that. Thank you!
