ECT housing
Old Jan 18, 2014 | 08:28 PM
svp_evo's Avatar
svp_evo
ECT housing
So I am building my new motor, and going through the old one pulling off what I can (most of it is either seized or rusted on). One of the items that is refusing to come out is the ECT Housing (I am guessing at the name). Its the inlet/outlet for water to TB and heater. I went to a pick and pull and there were 3 there but all were in as bad a shape as the one I have now. So I have two questions...
1. whats the proper name so I can make a vane attempt at trying to buy one new?
2. If I cant find one new I was thinking I could make something out of brass as long as I can find a T fitting with the right thread size, what size port is it in the manifold?
The wrench I was using on the lower nut was a 29mm open end, but I could not get it to loosen after 2hrs of liquid wrench.
Old Jan 18, 2014 | 08:59 PM
danr1's Avatar
danr1
Scroll down to post #10,
https://www.ford-trucks.com/forums/9...il-cooler.html
I believe its the part you are referring to.
Old Jan 19, 2014 | 09:52 AM
svp_evo's Avatar
svp_evo
Thanks Dan,
That would be the one.
damcnutt
6.7L Power Stroke Diesel
27
Sep 5, 2016 04:51 PM
Brother Les
Mar 1, 2013 04:53 PM
caverjoe
20
Jan 1, 2012 08:42 AM
chill9800
Oct 20, 2004 08:24 PM
