DPF Delete POST EPA Preventing Sale of Tuners
LOL, me too, but I've got a lot of other states to go to yet, probably won't be able to get to all in my lifetime so not going to CA doesn't dismay me. Everybody I know that live there are leaving so that must tell you something.
I've heard of a couple of instances of roadside diesel checks in SoCal quite a few years back, but to be perfectly honest, I've never encountered one wherever I've gone. I'm situated up in the Bay Area and have ventured down south on many occasions, like Disneyland area :-).
I do see a few tuned trucks every once in a while...but there aren't that many. I think the inconvenience of returning to stock every couple of years becomes a drag.
The allure of the weather here keeps people from leaving though it's like a zoo here in Sillycone Valley and insanely expensive to live here, so you won't miss anything coming here in that regard. LOL
It's sunny and 65F out today with maybe some brief showers for the first time in 3 months later this week. We're also in the middle of supposedly one of the worst droughts. The last time it snowed down here was a couple of hours in 1977. LOL
so you tune the engine so the engine doesn’t dump fuel in 7 and 8 in the exhaust stroke to send fuel to the DPF to burn the soot....does the catalytic converter do anything with the fuel? or does it go through the cat to the DPF. The DPF needs to be "bypassed" because if you don’t...it will plug up with soot....is the CAT the same way? i was thinking on that DPF...a concrete core drill bit would go through that ceramic material nicely....maybe nice enough that you wouldn’t need to run a pipe down the inside of it. Here in Spokane, Washington, i have been able to get a 6.4 L with DPF delete (replacement pipe) and a 6.0 with EGR delete to pass emissions. (they hook up to the battery and have sensors on the tail pipe, and then they have you do a snap test, and this is where it gets tricky...even a new stock 6.0, 6.4 would fail this test...because they literally tell you push the pedal to the floor...and when i was young and dumb, i listened to them...and failed....so now you put your other foot behind the pedal to give you a consistent stopping point, and then you do the snap test, it cuts you back to like 75% pedal...and then you pass, and that’s how we have passed a dpf deleted 6.4 and a 6.0 egr deleted).<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
The following users liked this post:
Amen, especially if you use your truck for a daily driver. Now all you have to do is pay attention to the fuel you buy, treat it, drain it, check the coolant every so often and drive it. Good thing I like to putz with things, and of course I love my truck.
I have been wanting to delete my DPF and, of course, waited too long to buy a tuner so I'm out of luck unless I can buy one now from one of the places listed here. I have 2 questions. !) I'm not interested in tuning the truck for extra power/ etc., I just want to delete the dpf. Do any of the tuners that still allow you to delete the DPF have stock tunes? 2) Here in TN we have emissions testing. They do not check the exhaust, or even look under the truck. They simply plug in to the OBD port and start it. Then look at the monitor to check the ECM I assume. Would I have to go through the process of reinstalling the DPF and de-tuning the truck every year with one of these tuners? Thanks for any advice.
H&S mini has a stock tune, not sure about Spartan. But you must make sure you are getting a DPF delete capable tuner. There is also a product called DPF-R (I think that's right) that only allows you to delete the DPF. They used to be on ebay. Find a diesel speed shop and they will be able to help you. I'm 71 and pretty sure I could return my truck to stock in an hour or so. It's not a big deal so long as you take the DOC (CAT) off with the DPF. Just 3 bolts, 3 sensors, a hanger and a clamp as I recall.
When I had my 6.4, I did the DPF-r not Plus as the Plus has a tune which give you a bit more performance. It performed well and was easy as its all voice prompts. I deleted the catalyst and DPF and it also requires you to use blocker plates to block the EGR. I gained a bit on fuel mileage, not much. and performance was noticeable, and it sounded like a truck when we finished. It took about an hour with 2 people and a lift. Very easy. I believe Gearboxz is still selling them but they are twice the price as they were a year ago. You must get delete pipes that have bungs so the sensors can be reused. It is stackable with other tuners. Would I do it again? gosh yes, in a heartbeat.
#28
I've been doing a lot of research on tuners and so far the one I am leaning towards is the Edge Evolution CTS (Color Touch screen) Diesel (85200). For $649 it says it does what I want, which is fuel mileage and DPF delete. Gotta save my pennies but that's what I am looking to do. Besides it has a pod that goes on the left side of your dash to make the install almost look factory. If anyone has any thoughts on these tuners please let me know GOOD or Bad.
#29
#30
I like the H&S a lot better for the tranny tunes and the EGR shut off but given the extra $1000 dollars (I bought my H&S pre EPA raid for $700) you would have to pay I can understand your decision. Over all my rating for the Edge is positive. Hope this helps.
