'98 E350 pass van need rubber mats
They want a factory type rubber floor linerset, not carpet again like on a newer E350 they have.
The dealer says the factory rubber liner is discontinued.
Anyone know of aftermarket rubber liner set? I've also tried Weathertech, Husky, etc. with no luck on a full set.
They really want a full liner, not just floor mats, but ?
OR
Will a newer E350 factory rubber liner work?
Thanks in Advance,
Matless near Fresno
If so it's possible to purchase a new full length rubber mat as comes with the cargo version of the extended body E-Series. From at least '97 until today the floors are all the same. New OEM from a dealer would be crazy money---I'd shop eBay for a new take-out piece like this one: http://www.ebay.com/itm/97-AND-UP-FORD-ECONOLINE-15-PASSENGER-RUBBER-FLOOR-MAT-REAR-OEM-/151206378337?pt=LH_DefaultDomain_0&hash=item23349a3b61
I've used that seller myself several times in the past--have even visited their outfit in person--great guys to deal with.
Another issue may be the condition of the existing floor---carpeting and even the OEM mats have a tendency to promote rust because they absorb and hold moisture close to the metal floor. Not to alarm you rather forewarning what might be lurking under the original carpet.
Hope this helps!
Yes, it's windows all around so I guess it is a Club Wagon.
The ebay you found could be the answer, thanks for your time. I'll forward the link after verifying.
Great help, and thanks again!
