Font diff cover bolt removal (Allen head)
Old Jan 15, 2014 | 03:09 PM
bkuuz1's Avatar
bkuuz1
So, after working all night and not being able to sleep much today, I decided I would change the oil in the front diff. Yep, you guessed it, the 5/16 Allen head bolt stripped out on me today. I don't have a welder her at the house to weld a nut on top of it. Looking for some ideas as to what others have done to get it out that ran into this before. I've sprayed it down with penetrate oil but I don't think that is going to work.
Thanks
Old Jan 15, 2014 | 03:16 PM
Pikachu's Avatar
Pikachu
Maybe you can drive a torx bit in to get a bite on it.
Old Jan 15, 2014 | 03:43 PM
snakedoc's Avatar
snakedoc
hit it with a hammer to try and losing it.
Old Jan 15, 2014 | 03:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
vice grip?
Old Jan 15, 2014 | 04:04 PM
JOHN2001's Avatar
JOHN2001
Originally Posted by A/Ox4
vice grip?
A small pipe wrench is even better if it's possible to get on there.
Old Jan 15, 2014 | 07:14 PM
bkuuz1's Avatar
bkuuz1
Thanks for the replies.
Yep, I've tried everything listed so far except the torx bit. I'm thinking at this point the better thing to do is to fit a bolt inside the stripped out Allen head and then tack the new bolt to the stripped head. I'm thinking that should allow me to work the old bolt out of the casing.
Just thinking out loud at this point. Of course it has to be the one that doesn't have much room to work with.
Old Jan 15, 2014 | 07:40 PM
crop harvester's Avatar
crop harvester
take a tapered punch with a small hammer and tap in the center until your arm gets tired, not real hard just good solid hit,then try removing & repeat if needed.
Old Jan 15, 2014 | 07:41 PM
JOHN2001's Avatar
JOHN2001
Now that we can see what you're working with I agree with you wait til you can get a welder handy. I don't remember if there metric or standard but try cross referencing the opposite with the closest size bigger. You never know. Sometimes at work I get lucky if it's a standard Allen head I'll grab my metrics (vice versa) find one that's just a tad bigger and peat the snot out of it until I force it into it's new home. Sometimes it works sometimes it doesn't.
Old Jan 15, 2014 | 09:52 PM
SARDiverDan's Avatar
SARDiverDan
Go to the local auto parts store and pick up a set of bolt-grip sockets. They have cutting teeth in them that grip the bolt head so you can take them out.
Old Jan 16, 2014 | 12:57 AM
USMCJosh's Avatar
USMCJosh
I'd smack the hell out of it w/ a hammer and get a similar sized torx in there or a good similar sized extractor.
Old Jan 19, 2014 | 10:21 AM
bkuuz1's Avatar
bkuuz1
Wanted to give an updated to this thread.
This is how I ended up getting the Allen head bolt out of the diff. Took longer to drag out the welder than to get the bolt out. Not my best welding job but it worked.
Old Jan 19, 2014 | 10:31 AM
JOHN2001's Avatar
JOHN2001
Good job. At a time like that the look of the welds don't matter. If you're fabbing something then I would give you grief about it.
Old Jan 19, 2014 | 11:00 AM
jetdoc's Avatar
jetdoc
I bought the Irwin external easy out set from Home Depot. Worth its weight in gold I'll tell ya!
9-pc Fractional Bolt Extractor Set - Tools - IRWIN TOOLS
Old Jan 19, 2014 | 11:23 AM
barnhartred's Avatar
barnhartred
If you think something is going to give you trouble to remove before you start you can apply a small amount of valve grinding compound to your tool, this has helped me immensely with stubborn fasteners.
CousinCarl
16
Aug 4, 2018 01:00 PM
MikeMcCasland
Dec 17, 2009 02:53 PM
JRS2
Jan 22, 2009 10:23 PM
Pocket
Feb 6, 2007 01:40 PM
Polkat
Dec 10, 2002 10:20 PM
