HPOP gasket
Old Jan 14, 2014 | 12:58 PM
Jerry Chaney's Avatar
Jerry Chaney
HPOP gasket
how do I secure the gasket when I install the HPOP back on truck?
Old Jan 14, 2014 | 01:24 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
Just partially stick the mounting bolts in there and start one the get the other side lined up....
Old Jan 14, 2014 | 03:04 PM
F250_'s Avatar
F250_
Just make sure to not put it on backwards. My son did that and made a really big mess REALLY FAST when he started the engine.
Old Jan 14, 2014 | 06:58 PM
t.scottNDU's Avatar
t.scottNDU
Ouch! Bet that was ugly. Sounds like something I'd do...
Old Jan 14, 2014 | 09:47 PM
MTDewX's Avatar
MTDewX
put a little oil on it along with the bolts.
Old Jan 14, 2014 | 09:50 PM
whitetmw's Avatar
whitetmw
Spray Tac works well also. Just a light coat.
Old Jan 15, 2014 | 08:02 AM
Jerry Chaney
I believe the HPOP gasket go's on one way.
Old Jan 15, 2014 | 08:17 AM
F250_'s Avatar
F250_
Believe me, you can put it on backwards, though, because of the bolt hole positioning. You are correct, through, there is only one right way to put it on, and if you put it on backwards, you get oil sprayed out all over the place very quickly due to the misalignment of gasket surfaces between the ports on the HPOP!
Old Jan 15, 2014 | 09:36 AM
Jerry Chaney
OK. So do I need to soak injectors with oil before installing back in?
Old Jan 15, 2014 | 02:10 PM
Jerry Chaney
HPOP back on
ok then, after bolting on HPOP, (don't have torque wrench so I just tighten the **** out of it) went to bolt on the front cover, does it need gasket or o-ring or what? any help
Old Jan 15, 2014 | 05:21 PM
F250_'s Avatar
F250_
Front cover? Not sure what you're referring to.
Old Jan 15, 2014 | 06:35 PM
Jerry Chaney
the plate that has to be removed to loosen bolt on HPOP
Old Jan 15, 2014 | 06:43 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
There isn't a gasket for that cover, you use a gasket maker. The Ford grey stuff if the best, but I'm sure you don't have any of that. Just use a good gasket maker and you'll be fine.
Old Jan 16, 2014 | 07:51 AM
Jerry Chaney
great.. thanks man.
Old Jan 16, 2014 | 08:40 AM
F250_'s Avatar
F250_
Sorry... I didn't remember that being there. It's only been about three years since my son worked on his HPOP, I've not had to do anything on mine yet, and the one on my Excursion has only received a new IPR (installed from the rear w/o removing the HPOP).
F-250 restorer
Apr 23, 2018 01:25 PM
ottoparts
Apr 26, 2014 06:04 PM
emkay4597
Feb 4, 2011 08:26 PM
jenkinsj
Nov 26, 2005 07:33 AM
Sixoh
Jul 27, 2003 05:22 PM
