No Power
Old Jan 13, 2014 | 09:57 PM
christopher.oconnor's Avatar
christopher.oconnor
No Power
I have a 2000 Ford Excursion 6.8 v10, this past weekend I removed the motor from another excursion (same year model and motor) and put it into mine. Both motors ran before swap-out and everything was working on my vehicle before swapping them, the only reason I changed them out was because both of my heads had one spark plug hole stripped out and i got the motor for free. My problem now is that I have no electrical power anywhere in my vehicle not for dome lights when door opens nothing. The battery has 12.42 volts coming out of it, if I run a test wire straight from the battery to the small cable on the starter the dash lights will flicker and if I put it too the larger cable it does nothing. Now I may be wrong but if I remember correctly when I touch said wire to starter it should try to turn over and crank up. If someone can give me ideas on what to test I would greatly appreciate it.
Old Jan 13, 2014 | 10:33 PM
hav24wheel's Avatar
hav24wheel
Should be one little wire to the little post, and the rest down there go to the big post that the big wire from goes to. I think anyways, it's been a wile since I've looked at the starter.
Or do these starters have two little posts and one big one?
Old Jan 13, 2014 | 10:42 PM
sandfarmer's Avatar
sandfarmer
Sure sounds like a ground problem, I feel like it's going to be super simple when you find it.
Old Jan 13, 2014 | 10:54 PM
Stewart_H's Avatar
Stewart_H
I'm sorry Christopher, I'm not trying to be "that guy" but for want of installing two threaded bushing spark plug hole inserts, you swapped the whole engine? Oh my....
Stewart
Old Jan 14, 2014 | 01:06 AM
Stebs's Avatar
Stebs
Stewart
seems to me that swapping the heads would have been easier... I think...
Old Jan 14, 2014 | 02:59 AM
Stewart_H's Avatar
Stewart_H
I wouldn't even do that when all that was needed was two of these:
Stewart
Old Jan 14, 2014 | 06:28 PM
christopher.oconnor
Stewart
I would have just replaced the heads but didn't have the money to buy the gaskets for them and the intake and exhaust manifolds so unfortunately I had to do that.
Old Jan 15, 2014 | 02:58 AM
Stewart_H's Avatar
Stewart_H
I didn't suggest replacing the heads. I opined that it would have been cheaper and easier if you had fixed the blown plug by installing a threaded aluminum bushing.
But like I said, I don't wanna be "that guy" and I think no matter how I post, I'm gonna come across that way.
Since I don't wanna rain on your thread brother, especially when I can't help with your problem, I'm gonna wish you luck and hope someone can post good help and tech for you.
Stewart
RAY1986F150
20
May 27, 2011 07:14 AM
Farmboy1285
15
Nov 23, 2010 04:02 PM
TucsonCowan
18
Apr 8, 2007 05:27 PM
sooline1
Oct 31, 2006 05:25 PM
rocky50
May 29, 2000 11:02 PM
