ok to start off with the truck runs fine,and starts fine nothing has changed.but I had to put a radiator in the other day,was leaking around the plastic tank on the bottom,put a new thermostat in along with a new radiator cap.now here is where it gets interesting even before,and even now after the engine cools overnight the cooling system is still pressurized.the guy who works on my truck told it was more than likely a head gasket or maybe both,and that's probably why the tank started leaking.any thoughts on this.it has 118000 miles oil cooler has never been changed,does have an egr cooler delete.
