vibration
Old Jan 13, 2014 | 01:42 PM
retired09's Avatar
retired09
vibration
I got a 2004 going down the high way at 50 and up to maybe 70 i get a vibration and it sounds like road noise one ford dealer said it was a front wheel bearing so had it changed still have it. took it to a different shop still cant find any thing so i need help.
Old Jan 13, 2014 | 01:46 PM
Unrealo4's Avatar
Unrealo4
Center bearing on your driveshaft? Maybe your hubs are stuck in lock or u joint.
Old Jan 13, 2014 | 02:04 PM
npccpartsman's Avatar
npccpartsman
What cab and drive configuration do you have? 2wd/4wd, std cab, ext cab, crew cab?
Old Jan 13, 2014 | 06:48 PM
04badford's Avatar
04badford
This could be a number of things, Carrier bearing, dive line, 4x4 drive link, Tires, Shocks, Ncpartsman asked and is your truck lifted?
Old Jan 15, 2014 | 08:13 AM
retired09's Avatar
retired09
I have a 4x4 super duty 4 door 8ft bed nothing modified
Old Jan 15, 2014 | 08:16 AM
retired09's Avatar
retired09
yea i thought it was the carrier also and i told the shop where i took it. i only got 189.000 on the truck and the u joints never been changed to thats why i mentioned it to the shop and he said the drive train was good and tight.
Old Jan 15, 2014 | 08:56 AM
TxMav's Avatar
TxMav
I have a similar issue. '06 F250 4x4 SWB CC, all stock. I rotated and balanced the tires but it made no improvement. It's not horrible, but definitely noticeable. I wonder if the tires are cupped (or cupping?). My tires still have about 75% tread life on them. It really smooths out at about 75 mph and up, which could get costly .
I'll be following this thread.
Old Jan 15, 2014 | 10:52 AM
clevelandtundra's Avatar
clevelandtundra
I have the same exact problem. I drive a 06 Extended Cab Short Bed. Crawled under and tugged on the driveshaft and everything seems to be ok still. Rather not splurge $80 on a diagnostic fee for a 'everything looks tight still.'
I'm running practically new BFG Rugged Trail T/As and the PO had a set on there too beforehand. I'm due for a rotation but I doubt it'll fix it. I wonder if its the BFGs?
Old Jan 15, 2014 | 11:31 AM
Unrealo4's Avatar
Unrealo4
My stock truck made some weird vibrations when I first bought it. I made some shims to drop the center support bearing down a 1/2. And that stopped them, but I cant remember when I was feeling them. I kniw for sure when I was starting to move in 1st gear.
Old Jan 15, 2014 | 11:42 AM
TxMav's Avatar
TxMav
Originally Posted by clevelandtundra
I have the same exact problem. I drive a 06 Extended Cab Short Bed. Crawled under and tugged on the driveshaft and everything seems to be ok still. Rather not splurge $80 on a diagnostic fee for a 'everything looks tight still.' I'm running practically new BFG Rugged Trail T/As and the PO had a set on there too beforehand. I'm due for a rotation but I doubt it'll fix it. I wonder if its the BFGs?
I'm running Michelin LTX/AT's.
Old Jan 16, 2014 | 12:13 AM
04badford's Avatar
04badford
Warped Rotors, may need to turn them with new brake pads, DBL check Calipers too .Also I had one shop put a heafty ding in my rim took it back to them to find out two rims and lugs were not torx right, rims were jacked up by loose lug nuts
Old Jan 16, 2014 | 12:40 AM
04badford's Avatar
04badford
https://www.ford-trucks.com/forums/1...e-time-72.html
Please go to last page 72 for more Info found
Old Jan 16, 2014 | 04:06 AM
Yahiko's Avatar
Yahiko
Here is a link to the right post.
The driveling testing info is in the PDFs that I posted.
There is a lot of info and your going to have to read
all of them to get the full scope of the testing.
Sean
Codyaye
Feb 24, 2017 02:04 PM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
Dec 15, 2011 11:30 PM
BENG0924
Sep 6, 2008 01:46 PM
kidoo
May 15, 2006 05:07 PM
un4givn
Mar 18, 2003 06:55 PM
