steering
Old Jan 13, 2014 | 10:41 AM
SuperDuty93's Avatar
SuperDuty93
steering
So on my highboy there is a 2wd ps box. I wish it was a 4x4 box but the frame has been notched and boxed for the 2wd one and now without spending hours hacking my frame up again I csnt get the 4x4 box to fit. So currently its a 2wd box doing the push my pull you design as I call it. I'm wondering if there is a cost friendly way to just leave the current ps box how it is and do a crossover system? Thinking that it might be a little easier on the ps box?
EDIT: Its a 78 D44 front end
Old Jan 13, 2014 | 10:46 AM
SuperDuty93
Genuine Bullet Proof Steering Systems FORD Pricing & Options found that link on hio's hyperlink page thingy.still kinda pricy imo
Old Jan 13, 2014 | 08:20 PM
SuperDuty93
Hmm so 60 views.... 200+ people viewing this section on FTE and not one person has done crossover or used this kit? Interesting...
Old Jan 13, 2014 | 09:26 PM
co425's Avatar
co425
Should be able to throw on a drop pitman and a crossover arm. You probably have to drill and tap your passenger knuckle though. I can see it working , but you may have to clearance your crossmember.
Old Jan 13, 2014 | 09:36 PM
SuperDuty93
Clearance the crossmember? Does the crossover arm go above or below the pass springs?
Also any suggestions on a kit or drop pitman? 74 2wd ps box, and its a 78 f250 front end d44
EDIT: this on seems like it will work for the drop but will it fit a 2wd box... id assume yes since the 78/79 4x4 pitman fits on my 2wd box.
http://broncograveyard.com/bronco/i-...f250-f350.html
Im a little worried about spring clearance with the drop pitman.. But they say on that link above from the company who makes a kit, that they can make bends so I can probably so a standard pitman that's not a drop to get the spring clearance and then have a bend to clear the crossmember and have it all positioned right.
Old Jan 13, 2014 | 11:46 PM
co425's Avatar
co425
It all depends on where the end of your pitman comes out. Most end up at a point where the drag link would hit the crossmember at some point in the travel.
Pitman arms are usually forged steel. You can bend them with a torch. Just make sure you let them slowly air cool. Water cooling them make them brittle.
Old Jan 13, 2014 | 11:57 PM
SuperDuty93
Ah ok cool! Ill call those guys up though and ask what I need to measure and all
F-250 restorer
Nov 1, 2014 12:57 AM
co425
19
Sep 22, 2014 02:09 PM
Xauterus
25
Jan 28, 2014 03:54 PM
muddwhumper
Jul 11, 2006 11:03 AM
