Replacing vacuum lines/hoses
Old Jan 13, 2014 | 12:57 AM
Junior Junior's Avatar
Junior Junior
Hey guys, just wondering if anyone here has ever done a total makeover on their 300 l6's vacuum lines, any tips you might have for the procedure and what diameter hose you used to do it.
I'm having all kinds of vacuum trouble lately with my '82 and definitely want to replace all of them one by one, but I have no idea if anything on the market is close to being as thin as the color-coded stock plastic lines (or if that strictly matters, even).
Any help in the right direction is appreciated, especially from those that have done something like this before. Thanks!
Old Jan 13, 2014 | 05:04 AM
KsCop's Avatar
KsCop
I just went through my whole system. While I did a computer delete and converted some systems to vacuum control, the end result was fewer vacuum lines.
That being said, this is what I had:
1/4" Vacuum line from carburetor bowl vent to EVAP
3/6" Vacuum line from Upper Port on PCV Valve to EVAP Purge
1/4" Vacuum line from Lower Port on PCV Valve to Intake Manifold
1/8" Vacuum line from Intake Vacuum source to Air Cleaner valve
1/8" Vacuum line from Ported Vacuum source to Ported Thermal Vacuum valve. Also 1/8" line from that valve to the EVAP Purge valve control
Bottom line; if you get 1/4, 3/16 and 1/8 lines in sufficient quantity, you should be good to go. Don't forget to put any thermal valves, restrictors, or solenoids back in line where they were. Also, if you have computer control, you'll have some vacuum 'hard lines' to deal with as well (EGR comes to mind)
Hope that helps..
Old Jan 13, 2014 | 01:03 PM
Dorsai's Avatar
Dorsai
It's pretty straightforward - as KsCop says, just get a bunch of the right diameters (you can always bring some pieces to the parts store and they'll give you matching hose) and get to it. I've been slowly replacing all my vacuum lines on my '80 F-150 as I do work on it, and I've never found any reason not to use bog-standard line from NAPA - it replaces the original plastic just fine. And as a bonus, the last batch I replaced fixed an intermittent idle miss that I'd never been able to track down.
Old Jan 13, 2014 | 03:33 PM
KsCop's Avatar
KsCop
Btw I was wrong on the 1/8
It's 5/32
Old Jan 17, 2014 | 05:39 AM
Junior Junior
Perfect information. Thank you so much, guys. One question, though - are those hose sizes for the outside or inside diameter? I've never dealt with vacuum hose before so I just want to be perfectly clear before ordering anything.
Old Jan 17, 2014 | 07:48 AM
85bigblue's Avatar
85bigblue
Jj inside i belive not 100percent I'm in the process of doing mine to.
Old Jan 17, 2014 | 09:46 AM
Dorsai's Avatar
Dorsai
Those are inside diameters, yes.
Old Jan 17, 2014 | 10:41 AM
85bigblue's Avatar
85bigblue
Kscop a quick question the thermal valves,restrictors, seliniods ect do they need replaced? Is there ways to check them to makes sure they work correctly. All the help is greatly apprciated thank you guys
Chris 97 F150
1997 - 2003 F150
20
Jun 5, 2019 02:19 PM
MilePostZero
Sep 4, 2018 10:54 AM
76ClydeF100
Jan 22, 2014 12:15 PM
BigBlue92
May 24, 2011 10:09 AM
Gunner33
May 11, 2009 07:08 AM
