2000 Ranger Won't Start
Old Jan 12, 2014 | 02:22 PM
deathsfriend_99's Avatar
deathsfriend_99
I have a 2000 Ranger 4.0L manual transmission. I just replaced the starter/solenoid on it a few days ago. I went to start it, and I got 1 click and the whole system goes dead (ie: lights, instrument panel, everything!) I checked all the fuses and the starter relay in the fuse box. All good. I tested the battery, it's charged and good. I even tried jumping it. Same problem.
I can remove power from the system, re-apply power and same issue. I'm not even sure where to start here. I checked the ground terminal on the battery. It's connected to the frame and clean. Cables are tight to the battery and clean.
What am I missing?
Old Jan 12, 2014 | 02:48 PM
deathsfriend_99
I (sheepishly) withdraw my question. The positive battery terminal "looked" clean. I ran some steel wool over it and now it's actually clean. Starts fine.
Old Jan 12, 2014 | 05:49 PM
cracked block's Avatar
cracked block
Looks ain't everything. Glad you found the problem!!
blue76
Jul 1, 2016 07:23 PM
brozenhimer
Mar 24, 2012 11:53 AM
sbjess03
Oct 26, 2010 02:07 PM
Darren_C_Kern
21
Aug 4, 2008 07:31 PM
GregAlex47
Dec 5, 2007 11:16 PM
