1987 Ranger
Old Mar 22, 2012 | 05:28 PM
brozenhimer's Avatar
brozenhimer
5th Gear
1987 Ranger
I've got a 2.9 2wd v6 that had been sitting for three years. i decided to hook up a battery to it and see if i could start it. as i hooked it up the starter solenoid started smoking so i unhooked the battery right away. i replaced the solenoid but nothing is working still.
Old Mar 23, 2012 | 11:32 AM
Phinxter's Avatar
Phinxter
When you say nothing, do you mean even the interior/dash? I would start checking fuses/fusible links, make sure the engine isn't seized.
Old Mar 23, 2012 | 03:04 PM
brozenhimer
5th Gear
the interior, the ignition, the lights, nothing works/turns on. i checked all the fuses and there good
Old Mar 23, 2012 | 05:05 PM
Phinxter's Avatar
Phinxter
I think for the time being I would disconnect the starter soleniod. Sounds like you might have a bad connection at the battery, maybe the cables or a cable is bad. hows the battery? I'ts very important to have clean terminals and clamped tight. Once you get that sorted I would actually check fuses with a test light as opposed to looking at them to see if power is even getting there.
Old Mar 24, 2012 | 11:53 AM
nobrandx's Avatar
nobrandx
Mine did the same thing, I put a new ground cable from the battery to frame and to the engine block and not one bit of trouble since-Hope this might help
That_Ford_Guy81
1978 - 1996 Big Bronco
Jun 10, 2019 07:55 PM
blue76
Jul 1, 2016 07:23 PM
glorric
Nov 26, 2012 07:41 PM
B-DOGG
Mar 10, 2006 09:21 PM
Laddsmith
Jul 23, 2004 01:40 PM
