truck wont start
Do you have good compression readings?
Good Spark?
Fuel?
Ignition Timing?
Valve Timing?
I'd check compression just to have a known starting point. If compression is off, I'd do a leak down test to determine if it's rings, valves, head gasket, plug holes (bad / leaking threads), etc.
While the plugs are out, I'd bring it to TDC on #1 COMPRESSION stroke and make sure the rotor is pointing to #1 plug wire. That will get your ignition timing close enough.
Also check the condition of the plugs. Plugs can tell you a lot (wet, carbon fouled, tan, broken, etc..)
When putting things back together, make sure the firing order is correct.
Then I'd put a spark tester on each cylinder and make sure I had good spark (one cylinder at a time as I don't have 6 spark testers..). If you have any issues here, then you have ignition issues. (module, distributor, cap, rotor, wires, power)
If that all checked out, I'd start looking at fuel / carburetor issues / choke / etc. (is fuel getting to the carburetor?, Carburetor itself?, Choke stuck?, etc.)
Vacuum leaks can be another issue, but they would have to be pretty darn bad for it not to start at all.
If the weather lets you:
Check and verify that your distributor is in correctly; check it the way KsCop says to.
If the distributor is only one tooth off--it won't start. Make sure the firing order is following correctly too--should sequence the direction of the rotor turning.
Shoot some starting fluid and see if you can get it to at least pop and sputter.
Not sure what to tell you about the compression readings; there are so many variables that can affect that, but as long as they are fairly even--she should run.
Do one more thing that is fast and easy:
Take your test light if you have one.
Then attach the test light clip to the (neg) battery cable and touch the test light probe to the green wire with the yellow stripe on it at the ignition coil and have someone crank the engine over. The test light should visibly blink while engine turns over--that tells you the ignition module is firing a signal to the coil. If the test light just sits there lit and doesn't blink/flicker then your module has went bad (OR) the stator inside the distributor has bit the dust as well. You said you have spark, but wouldn't hurt to check this as electrical parts don't warn you, they just quit working.
If it were me, I'd do a leak down test next and listen close
if you hear air in the intake - bad intake valves (or valve timing off)
Air in the exhaust - bad exhaust valves (or valve timing off)
Air out the breather - valve seals / guides
Air under the head - head gasket (can also spray soapy water along the head/block seam - bubbles mean a leak..)
When you tested compression: Was the throttle all the way open and you let it crank at least 5 revolutions per cylinder, correct?
Those compression numbers really bother me. They are all close enough to each other, but way too low. Assuming those are correct.
You may want to recheck those numbers: Throttle wide open, 5 cranks on each test. Make sure compression gauge is screwed in good and not leaking also. If those are the right numbers, do the leak down test. Fuel / Spark / Anything else won't much matter if that's the best compression you have.
Double check and let me know. I have seen timing chain / gear issues cause this since the valves then open and close at the wrong times. If valve timing is off too much, pistons can hit valves and that's not good..
You did say you replaced the timing set? If that's off, that would explain it..
Consider what has been done. It was running poorly so you changed the timing set. I assume you had a specific reason for that other than 'running poorly'?
If something wasn't done right when timing gears and / or chain / belt was messed with, and then the engine was cranked, you could have bent some valves. Assuming things are set correctly at this point and given the low compression readings, I'm thinking something ain't quite right in valve land..
If valve timing is off, they are open at the wrong time so compression can never really build. Given that symptom and the fact that you did work on the the timing set; I'm thinking that is your problem. Maybe I missed it, but why did you change the timing set in the first place? That might give some information as well.
Always start troubleshooting with the basics. I always go in this order: Compression, Spark, Fuel (to include things like air and fuel filters). If you have all that, it should at least try to start. After that it's ignition timing, plugs, carburetor settings (fine tuning items).
Hopefully, in your case the valve timing is just off and nothing else was damaged. If you have to pull the head, its heavy but not that difficult. If there is any piston damage from smacking into valves, well that's another story. Let's hope for the best and it's just valve timing with no damage.
It could also be a rounded cam problem, but if it was running before I think it's more likely valve timing. Just my 2 cents
