v8 engine noise
Old Jan 12, 2014 | 01:17 PM
daltonjamesadams's Avatar
daltonjamesadams
v8 engine noise
My 52 flat 8 is some times making a noise,does not sound like a rod,more of a coaking noise,on ocassion,seems to be in the top.I do not hear it at idle,and goes away when revved up.It does not have a deep sound like rods i have heard before.I am not at the point to want to do any serious engine work right now,but do not want to damage either.Experts chime in please.
Old Jan 12, 2014 | 02:49 PM
raytasch's Avatar
raytasch
Believe Nothing
An accurate oil pressure reading with the given oil weight. Hot and cold readings might help determine if it is a lower end problem.
Old Jan 12, 2014 | 03:08 PM
daltonjamesadams
No gauge,will i get an accurate reading where thecoriginal sending unit is? Have no idea of oil weight,going to change it to 30 non detergent.Bad carb,but will omewhat idle .
Old Jan 13, 2014 | 02:05 PM
bra$$monkey's Avatar
bra$$monkey
please put some video on youtube with good audio
Old Jan 13, 2014 | 02:10 PM
CharlieLed's Avatar
CharlieLed
Sounds like it could be a sticking valve...maybe time for some Marvel Mystery Oil.
Old Jan 13, 2014 | 02:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Please do not use non-detergent oil, unless you know it is full of sludge already. In which case what do you hope to gain by running it?
Old Jan 13, 2014 | 06:19 PM
daltonjamesadams
I hope,it,is,a sticking valve,it was previously popping some.My engine is pretty gunked up,i thought this was the oil ijtended for this engine,i am open for info.
Old Jan 14, 2014 | 01:32 AM
big job's Avatar
big job
Sounds like a noise I had,, everything was ruled out not rods mains wrist pins, none
of that, turned out to be my fibre timing gear went south. so pop the cover and
check that.
Old Jan 14, 2014 | 05:31 AM
daltonjamesadams
Thanks for the replies.I have no experience around these engines.
Old Jan 14, 2014 | 09:30 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this an engine that was recently driven regularly, that suddenly started doing this? Or is it a barn find that has been sitting for years and you are trying to get back on the road?
Old Jan 14, 2014 | 10:24 AM
GB SISSON's Avatar
GB SISSON
What about what Josh found in his intake. It's on page 2 of my current thread about an 8ba. I have a very similar sound in my small cummins that's in my '59. Mine makes a lightweight, odd sound for a short duration in mid revs. Not there at idle, not there at speed, just like yours. Josh's picture got me thinking about my diesel, maybe he'll chime in and tell us what that bolt sounded like. It's an amazing photo for sure.
Old Jan 14, 2014 | 04:44 PM
daltonjamesadams
Its a thicket find,has not run in 20 years until about 2 years ago.Exhaust were rusted off at the manifold until i built a crossover this summer.I do not think it is serious,does not have a pattern to it.I have a lot of mechanical experience,just not with flathead v8s.Keep the sugestions coming though,you always can learn.!!
Toppa
Modular V8 (4.6L, 5.4L)
Jul 14, 2015 02:24 PM
okiepc1
13
Sep 20, 2009 08:33 PM
mightymoose2
Modular V10 (6.8l)
Sep 18, 2006 10:41 AM
jonney_boy
1997 - 2003 F150
Mar 14, 2006 04:48 PM
Like M. Fords
Dec 2, 2001 09:39 AM
