CB ant. question?
Old Jun 26, 2003 | 09:35 PM
alpine's Avatar
alpine
CB ant. question?
I want to put a whip on my 84 f-150 super cab, but I am unsure of where to run the wire! I dont want my cb antena going through my back widnow or my doors. So How/where did you all run yours?
Thanks,
Alpine
Old Jun 26, 2003 | 10:05 PM
Txquadhunter24's Avatar
Txquadhunter24
CB ant. question?
most drill a hole in the lower back of the cab to run thru cable thru. then drill a hole thru a gromlet to seal it or use a sealer to seal around the cable
Old Jun 27, 2003 | 12:47 AM
Hillbillywagon's Avatar
Hillbillywagon
CB ant. question?
Check behind the seat. My truck had some holes with removable plastic plugs about the size of a snuff can. I drilled out one of them and ran my wire through it with a gormet.
Old Jun 27, 2003 | 12:32 PM
79_250RangerLariat's Avatar
79_250RangerLariat
CB ant. question?
Where are you planning on mounting the antenna? If the coax is long enuf you can run it out thru the firewall (should be lots of extra rubber plugs etc for you to go thru) and then under the cab.
Old Jun 27, 2003 | 09:20 PM
Boss50's Avatar
Boss50
CB ant. question?
I put my wires through the vent windows, but that only works if you put your antenna(s) on the mirriors.
Old Jun 30, 2003 | 11:02 AM
steve83's Avatar
steve83
CB ant. question?
There's an unused rubber plug in the door jamb above & forward of the power door boot location. You can puch the antenna cable thru it and silicone it closed, then run the wire out to the mirror, if that's what you want.
99ExpyProblems
Dec 29, 2009 09:46 AM
danielguam
Dec 27, 2008 05:19 AM
alpine
32
May 2, 2007 08:04 PM
