Sponsored by: Real Truck
Rubbing noise while accelerating and decelerating-ball joints?
Old Jan 12, 2014 | 12:15 AM
Vijay's Avatar
Vijay
Before I ask questions, here is the symptom; while slowing down and taking off, there is a rubbing noise at certain frequency (appears like two tires are rubbing although they are not). I just replaced hubs today with Moog brand in hopes of resolving this issue. Looks like it made no difference in noise…Could this be ball joint(that's what the shop told me)? If so, what brand to replace it with?
Old Feb 3, 2014 | 03:26 AM
56hawaiianfordman's Avatar
56hawaiianfordman
i had a similar problem. when excelerating the truck would shutter, as well as deceleration , between 28-40 mph. took it to ford did diagnostic found it was the u-joints and carrier bearing. they used the spicer ones, of course ford wanted $750 parts and labor...so i took the shaft off and took it to my nearest driveline place. roughly $200 later all was good. if you do it yourself make sure to mark the driveline on both ends. mine had a red mark on it already.
Old Feb 3, 2014 | 10:01 AM
Vijay's Avatar
Vijay
Thanks, I plan on doing the ball joints first and then I move to driveline...
Old Feb 3, 2014 | 11:10 AM
Bigpipes 35's Avatar
Bigpipes 35
I for the life of me cant figure out how a ball joint could produce the symptoms you are describing, Like said above its probably a ujoint or the carrier bearing..
Old May 2, 2014 | 01:52 PM
Vijay's Avatar
Vijay
Thanks, I think you are right. Any good place to buy these carrier bearing? Surprisingly, there is not much online.
Old May 2, 2014 | 03:39 PM
Bigpipes 35
Any parts house will have one, They are a bugger to get off , you will need to press them off and on...
h20thief
Dec 5, 2011 09:06 AM
mpriester
1997 - 2003 F150
Dec 22, 2010 04:17 PM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
Jul 11, 2004 05:59 PM
johnram1
Jul 20, 2003 12:14 AM
