Mike build 59 f100.
#61
I have to keep at it, If I slow I may lose interest. Also my neighbors are being cool with this in my front yard ( so far) If I show progress I don't think they will say anything. My yard is the sore eye with this in front right now.
I used seam sealer on the bottom today. Patched the last hole. Now I'm sanding the rest of the cab inside. The weather is good for work but not paint so much. We get lots of wind. So my goal is to have everything ready for a calm day and primer the inside and then painting black on the firewall and bottom of the out side cab.
Looks good at any rate.
#62
I painted the front flat black.
I primered the inside but did not get all of it. the wind is getting bad and there is rain on the way next week. Im tired of sanding off surface rust. I will put on a few more coats of primer to get a god base to sand.
I have also replace 2 of 6 bushings on the rear springs. Man that is a pain to get them out. My rear end should be ready to put back together next week. Im waiting on parts.. I have a shipment on the way but LMC put it on a truck as it has all the new glass in it too. free shipping saved me about 200$ I would have more done but it has been a week of fixing other stuff.
#64
#66
#70
All i did was cut out the old metal and weld in the new. The body mounts were left in place or marked and welded back in the same spot. the cab was firm and did not flex. I did the pans with the cab still on the frame then removed the cab to fin tune.
#71
I picked up the sheet metal and cut it with a cutoff wheel. I used cardbord to make a template . just lay down and start welding and hammering to fit.
#72
