always needs choke to start????... help please
Old Jun 26, 2003 | 08:47 PM
crash104936221's Avatar
crash104936221
hi
i have a 85' 300 with all stock parts it has a single barrel carter and i ALWAYS have to mess with the choke to get it to start after sitting more then 5+hrs 0*f or 75*+ it dosent matter
its overly anoying and has little power till it runs for 1-2 minutes
any ideas???
Thanks
Joe
Old Jun 30, 2003 | 04:41 PM
javi2001's Avatar
javi2001
If engine is bellow 25°C it will be necessary, especially if engine has low compression or not Tuned Up.
Regards;
Old Jun 30, 2003 | 04:52 PM
desperado_18_2000's Avatar
desperado_18_2000
I had this problem also with my truck and its 1v carter. The only solution i found was swapping on a new one, and wiring up the electric part of the choke. It starts every time now, and i don't have to climb under the hood to fiddle with it. Before i was having to do this every time i started the truck, if it had gone a few hours between starts.
Now its just nothing pat the gas twice, touch the key and go.
Hope that helped you. If you do need to wire your elec choke up, it should be connected either directly to the S terminal on your alternator, or into the S lead of your voltage regulator. If they were still external on your model of truck.
Sportsterengr
Feb 4, 2016 01:20 PM
Brian4618
Oct 30, 2015 09:30 AM
prestondave
Jan 7, 2013 10:43 PM
JReagan90
Sep 13, 2011 06:14 PM
CamoLaw
Jan 13, 2011 09:41 AM
