gtp38r questions
Old Jan 10, 2014 | 09:44 PM
psd96's Avatar
psd96
gtp38r questions
Dp tuner claims the gtp38r turbo is drop in for a 7.3, now does that mean it just "drops in" for both NBS and OBS? I wouldn't have to change manifolds or pedestal or anything? Picture looks similar styling as the stock turbo, but what about obs trucks? Haven't seen the turbos enough on NBS trucks to see how much of the mounting is the same as an obs. Sorry if I'm bringing up an old post, don't have tons of time to search the internet. Also, if anybody has one on their truck are they good? Just annoyed by the underpowered factory turbo.
Old Jan 11, 2014 | 03:21 AM
Ford4Life7.3's Avatar
Ford4Life7.3
The 38r can be used on an OBS but you need the NBS collector, up-pipes, drivers side exhaust manifold, and a few other things I'm sure I'm missing. As for the "underpowered factory turbo", here's the issue. Its not the turbo that is holding you back. In fact, the stock turbo can survive/support 325-350+ horsepower. The limiting factor as for power is the injectors. They just can't flow enough fuel to make bigger power, hence the reason many upgrade to larger injectors. The GTP38r is a great turbo though.
Old Jan 11, 2014 | 09:20 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
Is the gtp38r the stock SD one or is it the ball bearing aftermarket one?
I'm in the market for a turbo - or at least will be soon - and am trying to learn about what's what.
Old Jan 11, 2014 | 09:34 PM
Ford4Life7.3
Ball bearing
Old Jan 11, 2014 | 10:46 PM
OldWoodsDiesel
Thanks. The gtp38 is the stock sd one, right? Are the two the same aside from the bearings?
Old Jan 12, 2014 | 01:46 PM
psd96's Avatar
psd96
I figured if it was as simple swapping the factory for the 38r I would just do the turbo instead of having to pay someone to do injectors, but since there's so many extra expenses other than the turbo itself I will just stick with injectors. Plus the 38r sounds amazing. Stage ones with factory turbo it is then.
Old Jan 12, 2014 | 11:05 PM
fordman67's Avatar
fordman67
the gtp38r is a drop in SD turbo. IF you want to use on obs you will need ALL the sb turbo associated parts to make it happen.
microdevil45
Aug 14, 2012 06:19 AM
crazymut
17
Apr 22, 2008 09:42 PM
RocknXJ
36
Jul 29, 2007 10:56 AM
wayfastwhitey
Aug 4, 2005 08:53 PM
PowerstrokeJunkie
Aug 1, 2005 10:15 AM
