turbo upgrade?
Old Apr 21, 2008 | 07:20 PM
crazymut's Avatar
crazymut
turbo upgrade?
I am looking to do many upgrades, 4in. exhaust, Bts vb, gauges, DP Tuner, cooler and intercooler along with what is in my sig. My ? is, as far as turbos go, is it necessary to upgrade the turbo or is the stock one ok? I am not looking for more turbo noise just want to know if there is one out for more power. What will give me the most for the mods I am planning on doing?
Old Apr 21, 2008 | 08:57 PM
jtharvey's Avatar
jtharvey
Terry, you have several options. A Turbonetics drop in would work and not be too noisy from what I understand. A Garrett Ball Bearing would as well, although I don't believe they are available right now due to a redesign, and they are louder than stock. There's also the option of a van turbo or simply modifying your stock turbo with different exhaust and compressor housings. As you can see, there are many turbo options out there.
If I were doing one and intended to stick with stock injectors, I'd rebuild my stock one, so it's fresh, put a 1.0 exhaust housing on it, and an ATS compressor housing on the intake side. That would be a pretty good performing turbo, IMO, but would be about half the cost of any of the drop-ins.
Old Apr 21, 2008 | 09:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I'd have to agree with my bro, Jeremy here. The stock turbo modified how he said, with the intake and exhaust housings will stand up to alot of abuse. The problem is getting more fuel to the engine, not air. The stock turbo can pretty much clean up as much fuel as you can throw to it with stock injectors, in other words adding fuel would give you more power, without increasing sound too. Changing out the turbo with stock injectors really won't give you a noticeable Seat-of-The-Pants power increase. You can almost modify your stock turbo (about $600) and buy a set of injectors for close to the price of a drop-in ball bearing turbo!
Old Apr 21, 2008 | 10:12 PM
bigjake0524's Avatar
bigjake0524
Where is the best place to get the ATS compressor housing?
Just looked at ITP, think I should look before I ask. Unless you guys have a better idea.
Old Apr 21, 2008 | 11:30 PM
jtharvey's Avatar
jtharvey
ITP is a great place to buy from.
Old Apr 21, 2008 | 11:39 PM
ryaneverk2's Avatar
ryaneverk2
I wouldn't replace the stock turbo unless going to bigger-than-stock injectors.
PS - I got my ATS housing from Dennis at ITP, as well.
Old Apr 21, 2008 | 11:48 PM
That_Guy's Avatar
That_Guy
where would you get a bigger exaust housing for the stock turbo? and what would the size of that be?
Old Apr 21, 2008 | 11:57 PM
jtharvey's Avatar
jtharvey
I believe Bean's sells them and you can get a 1.0 A/R or a 1.15 A/R. Stock is 0.84 A/R and the 1.15 A/R is the same as a van turbo.
Old Apr 21, 2008 | 11:59 PM
That_Guy's Avatar
That_Guy
would the bigger exaust houseing be just as good as a van turbo or would upgrading the intake house be needed to ?
Old Apr 22, 2008 | 12:05 AM
jtharvey's Avatar
jtharvey
Well, if you put a 1.15 housing on the stock turbo, you essentially have a van turbo. That's what I did, as well as Kris did, a couple years ago. That turbo of mine eventually blew up from being run too hard with the stock exhaust housing on it, and I put a van turbo on in it's place. Performance between the two was essentially identical between the van and truck with housing.
The intake won't need to be upgraded unless you still have problems with surging. The larger exhaust housing does help to eliminate the surge though. I'd try the exhaust housing first, then if the ATS is needed becuase of surge, you can always add that later.
FWIW, the combo of the van turbo and ATS housing never once surged on me, not even with the B Code injectors in place.
Old Apr 22, 2008 | 12:13 AM
That_Guy's Avatar
That_Guy
Thanks Ill look into that, I have a WW waiting to be installed so Id try the new exaust housing and the WW and see if I still have surge.
You can take me off the list Jeremy, I think Im goin to go this route..
Old Apr 22, 2008 | 12:18 AM
That_Guy's Avatar
That_Guy
Is this what you were talkin about from beans?
BDP 1.0 turbo housing kit
This is a new product from BDP. This is a 1.0 turbine house to be a direct replacement for the stock .84 housing on the 99-03 powerstroke. This housing is non-wastegated (like the van turbo) with an adaptor to mount to the stock or modified exhaust system. With this kit you will eliminate the EBPV valve which also increases flow. This is a great turbo modification for those with the ATS compressor housing or wicked wheel. This housing will help eliminate the compressor surge commonly associated with the stock turbo, lower backpressure, and also decrease egt's up to 100 degrees.
Old Apr 22, 2008 | 12:22 AM
jtharvey's Avatar
jtharvey
Yes indeed, that's the one.
Old Apr 22, 2008 | 12:25 AM
That_Guy's Avatar
That_Guy
Thanks for the help
Sorry for hijacking the thread crazymut ... its kinda on topic lol
Old Apr 22, 2008 | 07:34 PM
LaJ10's Avatar
LaJ10
This is the deal I got.After talking to several people here and Ron that sells this it seeed to be a great option and the price was very competetive.
eBay Motors: 99 03 TURBO 7.3 POWERSTROKE TURBOCHARGER PERFORMANCE (item 110244594744 end time Apr-25-08 09:04:03 PDT)
It arrived quick ,but I havent put it all on yet
