Hyd. Clutch
Old Jun 26, 2003 | 07:53 PM
sinnes's Avatar
sinnes
Hyd. Clutch
87 Ford Ranger 2.9 V6 4x4 5 spd.....how do I diconnect internal
hydraulic clutch so I can remove the transmission. Plastic Hyd. hose attaches to a fitting at the top of the bell housing. I believe this is one year before the quick disconnect:
Old Jun 26, 2003 | 08:19 PM
WXboy's Avatar
WXboy
Hyd. Clutch
When we did my buddie's 88 a few weeks ago, the Haynes manual said you need a special tool in order to disconnect it. Since we had the tranny half way unbolted already and couldn't just run to the store, we used a pocket knife to depress the ring and pull it out the old fashioned way.
Old Jun 26, 2003 | 08:46 PM
georgiaborn73's Avatar
georgiaborn73
Hyd. Clutch
on ur hyd clutch connection.........the tool the haynes refers to is nothing more than a bbq/meat fork. i used an old bbq fork and bent the tines closer to fit the connection. once the tines depressed the ring i could pull her out.
Old Jun 27, 2003 | 12:12 AM
Racerguy's Avatar
Racerguy
Hyd. Clutch
You can usually push in the white collar thingy with a screwdriver too.
Old Jun 27, 2003 | 01:08 AM
sinnes's Avatar
sinnes
Hyd. Clutch
Hey everyone, thanks for the replies. I got that thing out tonight thanks to your help.
Steve, Great White North Vanc.,Canada
