Seat question
Old Jan 10, 2014 | 05:50 PM
wameyer's Avatar
wameyer
Seat question
OK I dont know where to post this. I know someone has done it but having a tough time finding it. I have a '99 psd f250 crew cab lariat, I just purchased seats from a 2005 F350 that are lariat heated and power. My seats are power but non heated is there a way to hook everything up and if so has anyone done this
Old Jan 10, 2014 | 07:31 PM
Franklin2's Avatar
Franklin2
Hopefully you got all the controllers with your new seats. Go to Autozone's site, I am sure they have all the diagrams for the 2005 seats. If I remember right, all you need is a fairly heavy circuit for the heat controllers and a smaller key-on circuit to trigger it all. You can come right off the battery with two 30 amp circuit breakers, run two 10 gauge wires from those into the cab, and supply the controller in each seat. I am going by memory on that also, but if it only takes one 30 amp circuit, you could do that also. Just copy what the diagrams have, though I would not try to tap into the existing fuse box for this(except for the key-on power), too complicated.
Old Jan 10, 2014 | 08:45 PM
wameyer's Avatar
wameyer
all the controllers? Like what.... I have the switches that are connected to the seats and thats it. What else do I need to grab, I can go back and get the parts from the guy I got the seats from I just need a list of what I need. Thank you
Old Jan 11, 2014 | 07:15 AM
Franklin2's Avatar
Franklin2
See that box? They call that the "heated seat module". I am not sure, but I am thinking it's mounted on or under the seat somewhere.
Here's the pass side seat. Looks like you only need one 30 amp circuit.
Here's a different diagram they have in the same section. This looks like the simpler version, I don't know what you have there, you will have to check the wire colors with the diagrams.
carbon coupe
Aug 14, 2019 07:25 AM
43tutor2
Ford Truck Parts for Sale
Dec 16, 2016 08:47 AM
Fordhearter
Jun 17, 2016 01:59 PM
mudmaker
18
Jun 5, 2010 01:01 PM
tetsuo73
Nov 23, 2009 07:49 AM
