Sponsored by: Real Truck
heater problems
Old Jan 10, 2014 | 04:54 PM
ballow97's Avatar
ballow97
heater problems
I have a 2000 f250 4x4 7.3 diesel. I had problems with my a/c and controls for sometime now. my a/c was blowing threw the defrost vent. I was told my blend door was bad. I bought a new blend door installed it,still doing the same thing. I was told to check my vacuum lines. I check them, they were bad. I replace my vacuum lines and my vac pump as well. that fixed my problem blowing threw the defrost vent. I can control my air flow from floor,dash vents and defrost vent. the problem I have, I not able to control my temperature when I turn my center **** from red to blue. It blows hot air and the air that is coming out of the vents isn't very strong at all. if anyone has had this problem and fix it. I would appreciate your help, Thanks
Old Feb 17, 2014 | 01:31 PM
tsaa2's Avatar
tsaa2
Having the same problem with 2003 5.4 f 250. Just wide open hot all the time.
Vsmith
Feb 8, 2019 10:46 AM
shakebaker69
1997 - 2003 F150
Sep 3, 2013 06:13 PM
ksubigbuck
Oct 15, 2007 01:39 PM
vicsr2
Jul 5, 2006 10:24 PM
jugz84
May 24, 2006 04:41 PM
