unknown electrical problem
Old Jan 9, 2014 | 11:07 PM
Zayne Davis's Avatar
Zayne Davis
Exclamation unknown electrical problem
I have a 1992 f250 7.3 idi. the truck has ran great for the 6 months that ive owed it but a couple days ago I went to start it and the tachometer, the oil pressure gauge and the battery gauge have stopped working. the transmission is now not down shifting as well. any suggestions?
Old Jan 10, 2014 | 03:59 PM
Perk85F250's Avatar
Perk85F250
Check your fuses, especially the one for your dome lights.
Old Jan 10, 2014 | 04:04 PM
Perk85F250's Avatar
Perk85F250
My previous comment about the dome/interior light fuse affects the speedometer so, it may not be on the same circuit.
Old Jan 10, 2014 | 08:19 PM
Zayne Davis
I checked all of the fuses and all of them are fine. I didn't realize it at the time but my gas gauge and oil temperature gauges aren't working either
Old Jan 10, 2014 | 10:33 PM
ifrythings's Avatar
ifrythings
Everything you said that died runs off of the same fuse, fuse 17, it also runs the overdrive cancel switch and diesel warning lights (water in fuel, wait to start, plugged fuel filter, engine warning and low vacuum switch)and the warning chime.
If the indicators are working and the fuse is good, I would pull the instrument cluster and see if one of the plugs on the back has a dirty connection.
Old Jan 12, 2014 | 09:06 PM
LSO1123's Avatar
LSO1123
Sounds like your cluster is bad. Had the same thing happen to the one in my '93. It will definitely cause your E4OD to act up as well.
f250mansc
Aug 20, 2011 09:21 AM
Ds7776
Jun 8, 2010 06:59 PM
mcne
Mar 20, 2007 08:37 PM
PowerStrokeMe
Electrical Systems/Wiring
Nov 13, 2006 08:43 PM
