Old Jan 9, 2014 | 06:00 PM
Starry's Avatar
Starry
Hi I have a 2001 7.3 with 265k on it.
I am new to the diesel world.
I am just curious if anyone out there has any suggestions on getting better MPG. I live in MN in the winter I am getting 11-12 in the summer 14-16. I am wanting to do whatever I can to get as much MPGS as possible.
Tuners, Intakes, Exhaust, whatever it takes.
If you have any suggestions I would really appreciate it!
Thank you!
Old Jan 9, 2014 | 06:08 PM
SARDiverDan's Avatar
SARDiverDan
Welcome to FTE. The first place to start would be in the "read first" section just above your post. Click on the second one (of the three listed) and you will find all kinds of info about this. Give it a few minutes and Tugly should be along (resident fuel miser) and he will give you more info on how to squeeze whatever MPG is left to give. The mileage you have listed is about normal and the more mods you do, the more "foot" you use to enjoy the mods and the then the fuel MPG goes out the window anyway.
Old Jan 9, 2014 | 06:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
i am in New Jersey, and see pretty much the same mileage in my 02 with 4.10 gears.
Old Jan 9, 2014 | 09:32 PM
daddyusmaximus's Avatar
daddyusmaximus
I don't feel so bad now. I'm about 1 mpg behind you, and I'm lifted, on 35s and running 4.30 gears... but I drive like a grandpa.
Old Jan 9, 2014 | 09:39 PM
JOHN2001's Avatar
JOHN2001
The only way to really improve your mileage is to make sure everything is up to 100% tuning wont get you mpg.... Changing your driving habits will keep it under 2000 rpm
Old Jan 9, 2014 | 11:14 PM
sand_fiend's Avatar
sand_fiend
winter blend fuel will decrease your mileage. i live in so cal and i also Get worse mileage with the winter blend fuel..
You could also check to see if your up pipes are leaking. look on the fire wall just behind the turbo where the doughnut type gasket is on the up pipe connection. look for black soot on the firewall directly across from the gasket. if you see a black streak at the same level, you have a leak and it will also hurt your mileage
Old Jan 10, 2014 | 08:09 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
If you ARE willing to do what it takes, Go with stock size tires. If the truck is running to specs, stock tires will probably get you more mpg than all those mods. Just sayin.
Old Jan 10, 2014 | 10:45 AM
daddyusmaximus
That's the major thing that affects me I'm sure... My lift, tires, and gears. I don't drive to work every day (retired) so I'm willing to pay at the pump for my off road capability. I don't get to go that often, but man, it's fun...
Old Jan 10, 2014 | 11:18 AM
JOHN2001's Avatar
JOHN2001
Look at my signature... It's a bad combination for mpgs... I average 14 and I beat the crap outta it (within reason).
Old Jan 10, 2014 | 03:46 PM
daddyusmaximus
Same goes for my mods. Bad combo for mpg good for fun on the trail...
...but I can't have a sig yet.
Old Jan 10, 2014 | 04:49 PM
dn29626's Avatar
dn29626
I rarely check my mileage, but it was in your range.
Old Jan 10, 2014 | 07:33 PM
camp nh's Avatar
camp nh
I have a 2001 as you see in signature and it's a dually. I am doing the same mileage as well.
Big_Man_Brad
25
Oct 10, 2008 10:32 PM
hoosier_daddy_47553
17
Nov 18, 2007 06:55 PM
powerstroke1869
Feb 11, 2007 09:27 PM
stangman67
Apr 2, 2004 10:44 AM
Kenworth
Dec 22, 2001 03:19 AM
