glow plug controller
Old Jan 8, 2014 | 06:46 PM
DmanNC's Avatar
DmanNC
Has anyone used the controller from oreillys or advance auto (bwd). It is $85 , the delphi and ford motorcraft is around $200.
Old Jan 8, 2014 | 08:08 PM
88beast's Avatar
88beast
i dont buy diesel parts from advanced, but bwd should be good
1986 Ford, F-250 - Glow Plugs Diesel Parts Selector
check out this one good stuff cheap
Old Jan 8, 2014 | 08:14 PM
DmanNC's Avatar
DmanNC
Cool, thanks mine is a 94, it's $59, that's even better!
Old Jan 8, 2014 | 10:21 PM
lindstromjd's Avatar
lindstromjd
Won't work on the '94. Completely different style.
Old Jan 8, 2014 | 10:32 PM
51fordf5's Avatar
51fordf5
I got mine from napa. I just needed the relay, but if you need the whole controller they have that too. Here's what I got (should be same style as yours):
NAPA AUTO PARTS
Here's the entire controller as a package:
NAPA AUTO PARTS
Maybe you can find it cheaper somewhere else online, but I couldn't wait around for shipping so I needed to get it locally.
Old Jan 9, 2014 | 06:54 AM
DmanNC's Avatar
DmanNC
I know you need beru glow plugs and international thermostat, I assume for the controller anything will work?
Old Jan 9, 2014 | 07:24 AM
lindstromjd
The thing to look out for, is that the "old" style (83-86) style is a "fail-closed" style controller. So when it fails, it fails with the contacts closed and gives full power to your glow plugs and it will take all your glow plugs with it. The "late" style (87-94) is a "fail-open" style. When it fails, it just burns out without closing any of the contacts, so your glow plugs don't burn out with it.
I can't say much about brands; the only ones I've ever seen and used for the early style was Ford. It sucked having to pay for it, too.
Old Jan 10, 2014 | 04:01 AM
Chevy_Eater's Avatar
Chevy_Eater
No brand experience with the newer style myself, I gave up on controllers and go manual on all my IDIs anymore.
But on the old style, when I had my '84 the store brand controller I put in it failed at right around a year, (killed all my GPs of course), so the next one I put in I got from the local International dealer. That one lasted many years and was still in service when I sold the truck.
That's just anecdotal of course, so it's just my 2 cents.
Old Jan 10, 2014 | 09:21 AM
Sycostang67's Avatar
Sycostang67
I have been using the BWD controller for over a year without issue. I need to replace my glow plugs right now as I have a few weak ones. I have the controller set up semi-manual right now. If the switch is on, the controller will run as normal. If I turn the switch off, the controller doesn't come on at all. This way I am not shortening the life of the plugs and controller by using them every time I start the truck, only when they are needed.
Resendiz
Jun 3, 2016 05:58 PM
Ricky Kuczmarski
May 2, 2016 08:15 PM
bobwhyte2002
May 28, 2012 03:18 AM
gmlawnandlandscape
Nov 27, 2011 10:28 PM
