Injector Help O 5.4 lord of troubleshooting
99 Exped 5.4
Getting lean code bank 1.
Replaced vacuum lines pcv assy, cracked rubber.
Replaced that stupid pressure sensor
Replaced pass o2 fwd sensor
Installed 1 new injector...no change.
Replaced all injectors cause it needed it anyway.
Needed to be done anyway, just making the expedition better for long travel move.
Threw a code again.
Unplugged every injector and number 5 only one that did not change idle.
Swapped with known good, ran engine and disconnected all again. Still number 5 no fire injector.
Performed wiggle check.
What next?
Threw a code again.
What next?
So if the PCM sees excess oxygen in the burnt gasses, it figures it needs to "add more fuel" to use this excess oxygen, which the PCM translates to "it running lean".
Just like us old carburetor guys think there is 'vacuum' within the intake manifold and when we go WOT we say the intake vacuum decreases.
The PCM thinks there is 'pressure' in the intake manifold (just that the pressure is less than atmospheric (aka Baro) pressure. When we go WOT the PCM says the intake 'pressure' increases , and that's why the PCM wants more fuel pressure to be able to inject fuel into that higher pressure area.
Sorry, sometimes I get carried away...........
Douglas Prewitt
1997-2006 Expedition & Navigator
07-08-2018 07:52 AM
husky562xp
05-16-2016 07:53 AM
Ryan Simpson
Modular V8 (4.6L, 5.4L)
04-11-2016 10:32 AM
