Difference in 1961 and 1964 frames?
Old Jan 8, 2014 | 08:13 AM
Slixty4's Avatar
Slixty4
So I am building a flareside f100 with a 331 and crown vic front suspension.
I bought a 1961 Flareside but the cab was in too bad of shape so I ended up stripping it and scrapping it.
Then I came across a great deal on a 1964 Longbed that was really too nice to tear apart but I ended up doing that anyway.
I am going to use the 1964 cab on the 1961 frame.
So the reason for posting is, I have noticed that my cab doesn't sit right on the '61 frame. It seems the cab mounts on the frame are different. Before I got rid of the long bed frame, I did cut off the cab mounts and the rears seem to be higher.
However, everything I read on the web says that frames from 61-64 are all the same. Has anyone else run into this issue?
Right now my plan is to just put a spacer on the back mounts and get longer bolts. But I would like to know the factory measurements if possible.
Thanks in advance and here is where the project is at this time. Just finished mounting the CV front end. Motor is built and my next step will be getting it in the frame and mocking up the motor mounts.
(BTW, I am not the most experienced welder. But I'm working on it.)
See how it looks like its tilting back?
Original 1964 tag. One owner truck
Old Jan 8, 2014 | 11:10 AM
William's Avatar
William
The cab mounts are easily adjustable by adding shims under the rubbers or squeezing the rubbers a bit more in front than in the rear. I see the fender to door gap looks really nice. I'd wait until the bed is mounted and then park it on a level floor and see how it looks. Nice work by the way.
Old Jan 8, 2014 | 11:24 AM
Slixty4's Avatar
Slixty4
Yeah, the door gaps do look pretty good for a cab that was just slung around and dropped onto the frame with a front end loader. I don't think the fenders have ever been separated from the cab so I have left them alone. I guess that little bit of height difference won't really cause any big problems.
I just would prefer to get it mounted on there properly for when I start making brake lines and setting up the steering
Old Jan 8, 2014 | 04:26 PM
jowilker's Avatar
jowilker
Slixty4, Where are you located in the Tarheel?
John
Old Jan 8, 2014 | 06:35 PM
garbz2's Avatar
garbz2
Order 64 to 66 cab insulators. They are thinner than the 61 to 63.
Garbz
Old Jan 9, 2014 | 07:55 AM
Shadowrider123's Avatar
Shadowrider123
What rear end are you using to get the 5x4.5 bolt pattern?
Old Jan 9, 2014 | 08:11 AM
tinman52's Avatar
tinman52
Welder User
What kind of welder are you using?(size, amps)
Old Jan 9, 2014 | 10:17 PM
Wet Wes's Avatar
Wet Wes
John
I too want to know where Sixty4 is too. I may want the same thing done.
Old Jan 10, 2014 | 03:39 AM
jowilker's Avatar
jowilker
It's so easy to place your location in your profile. Mines been in for 10 years +/-.
John
Old Jan 10, 2014 | 07:00 AM
Slixty4's Avatar
Slixty4
Well guys, sorry I haven't replied sooner but two days ago I came down with what I believe to be strep throat. I feel terrible even sitting at this computer so I will make this short and sweet and get more into detail later.
I am in Shelby NC.
Welder is a Hobart 110 hobby welder that I am running flux core wire (no gas)
Axle is explorer 8.8 with all the goodies. And yes its way too narrow compared to the CV front end but I plan to throw some wheels with a ton of dish back there to help even it out.
Old Jan 10, 2014 | 08:23 AM
Shadowrider123
Ive noticed that on all the CV pics that Ive seen posted the filler piece is always on top of the frame.
Is there a reason why other than a lower ride height vs having it under the frame?
Old Jan 10, 2014 | 08:56 AM
Slixty4's Avatar
Slixty4
I mounted mine that way simply to get it as low as possible. No other reason really
Old Jan 10, 2014 | 02:36 PM
Wet Wes's Avatar
Wet Wes
I am liking this build. Did you move the front axle centerline forward like most folks do? If so, how much? I have heard 1.25", 1.5" from others.
Old Jan 10, 2014 | 02:49 PM
Slixty4's Avatar
Slixty4
I did not. I didn't know people were doing that.
Old Jan 10, 2014 | 03:20 PM
Wet Wes's Avatar
Wet Wes
Wow! The reason I ask is it appears from your picture the front wheel lines up perfectly in the wheel well. Either other folks are doing it for engine clearance on the firewall or you just got it perfectly right. Rock on. I am admiring your work. Please keep sending pics.
