Tire question
Old Jan 7, 2014 | 08:00 PM
Mike1's Avatar
Mike1
Tire question
I had a flat the other day on the rear 95 F250 4x4 5.8L Manual. I had a spare changed over on the rim. Problem being that the spare I had put on is approximately 1 inch taller than the other rear tire. How big of a chance is it that the rear end will blow from running 2 different height tires? Can I take that odd ball tire and put it on the front as long as I don't use the 4x4? I need to buy another tire I know, I just won't have the money for about a week and my other car has a blown head gasket, it's just been to darn cold to work on it. Any thoughts are appreciated. Thanks.
Old Jan 7, 2014 | 08:19 PM
Big_Al59's Avatar
Big_Al59
Best bet would be running it on front, but i don't think you will hurt the rear diff unless you have a locker or posi. Did it last year for a few days without any issues.
Old Jan 7, 2014 | 08:34 PM
Mike1's Avatar
Mike1
As far as I know the rear end is stock. I've driven it about 60 miles like it is back and forth to work but I'm just paranoid because I always heard DO NOT run tires like that because it'll blow the diff.
Old Jan 7, 2014 | 08:53 PM
coxthecrazy's Avatar
coxthecrazy
A trac-lock was available from the factory. Check the data plate on the driver door jamb. H9 is a 3.55 trac-lock I know because my Bronco has it and I think a trac-lock 4.10 is either H1 or H4 but I can't remember But I'm pretty sure the code for any trac-lock starts with an H
Old Jan 7, 2014 | 10:18 PM
Mike1's Avatar
Mike1
I don't see anything on the door tag that says H9 or trac-lock. This site won't allow me to post pictures or attachments.
Old Jan 7, 2014 | 10:24 PM
blkF250HD's Avatar
blkF250HD
Put it on the front. The rear spider gears will be spinning continuously since one side will be spinning faster than the other, as if you were turning.
Old Jan 8, 2014 | 08:36 AM
coxthecrazy
Is there a 19,14, or 11? That would mean you have an open carrier for the rear differential
Old Jan 8, 2014 | 09:02 AM
Diesel_Brad's Avatar
Diesel_Brad
I would not worry about running the New tire on one side and old tire on the other UNLESS you have limited slip
On your door jam sticker
Under "axle" it will have a 2 digit code
OPEN axles
12---------2.73 gear ratio
17---------3.31 gear ratio
18---------3.08 gear ratio
19---------3.55 gear ratio
25---------4.10 gear ratio
29---------3.55 gear ratio
35---------4.10 gear ratio
39---------3.55 gear ratio
45---------4.10 gear ratio
49---------3.55 gear ratio
65---------4.10 gear ratio
68---------4.88 gear ratio
69---------3.55 gear ratio
72---------4.63 gear ratio
73---------5.13 gear ratio
LIMITED SLIP AXLES
B5----------4.10 gear ratio
B9----------3.55 gear ratio
C5----------4.10 gear ratio
C9----------3.55 gear ratio
D5----------4.10 gear ratio
F5----------4.10 gear ratio
H4----------3.54 gear ratio
H5----------4.10 gear ratio
H7----------3.31 gear ratio
H8----------3.08 gear ratio
H9----------3.55 gear ratio
Old Jan 8, 2014 | 10:04 AM
Mike1's Avatar
Mike1
Thank your replies. The Axle is 39 So I guess that means an open Axle.
blkF250HD, I'm going to switch tires today anyway. I did not realize that the rear tires actually had tubes in them. I have an extra 235/85/16 at the house. It's real low on tread but it has to be better than running a tube. The other 3 tires are General Ameritrac TR 235/85/16's while this one is a Goodyear 7.50x16. It's an old snow tire that looks like what you used to see on small dump trucks back in the 70's. I really didn't think much of them until they started going flat.
Again, thanks for all the replies, I appreciate it.
Pool Runner
2009 - 2014 F150
Aug 11, 2013 09:48 PM
Truck610
Jul 10, 2013 09:13 PM
grbarner
1997 - 2003 F150
Jan 3, 2011 05:02 PM
jason867
1983 - 2012 Ranger & B-Series
31
Feb 10, 2008 07:17 PM
LonW
Oct 3, 2007 01:41 PM
