Coolant change 101....HELP !!!
Old 01-06-2014, 01:31 AM
osteo16's Avatar
osteo16
osteo16 is offline
2004 6.0..... Did BeachBumbCooks flush, with thermostat on. Drove truck till therm opened, opened stopcock, drained, filled with distilled water and did again.. 4 times. Last drain, closed stopcock, started to put in GO5 and only got a little over 2 gallons in before degas was full. Anyone have any ideas.... Really bumbed at this point. Thanks for any input.
Osteo16
Old 01-06-2014, 02:55 AM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
not sure why this time its not re-filling this time around, try removing top hose to see if maybe its an air pocket thing.
Old 01-06-2014, 07:51 AM
69cj's Avatar
69cj
69cj is offline
To get the majority of water out you need to pull the lower hose and open both block pet*****. You can do it with one petcock but will take a little more flushing. When done add the proper amount of straight coolant for a 50/50 mix and then top off with distilled water.
Natcox012
01-24-2015 08:47 AM
ConvertedFord
11-22-2009 05:37 PM
Bunyon's_Ox
12-04-2008 08:05 AM
CptSD
07-03-2007 08:03 PM
AggiePSD
03-22-2003 09:54 AM
Quick Reply: Coolant change 101....HELP !!!
