6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
ordered tuner and pipe
Old Jan 5, 2014 | 08:37 PM
URDADDY's Avatar
URDADDY
Finally was able to order a tuner and pipe for my 09 F350. I went with the SCT because of cost and what I really felt I needed. Not doing the tuner to run hot tunes or anything just wanted to get rid of the stupid DPF and maybe get a little better gas mileage. Any tips on Install would be appreciated.
Thanks
Old Jan 5, 2014 | 11:00 PM
reaganla's Avatar
reaganla
The tuner is self explanitory, just plug into pcm and answer the questionss.
Are you just deleting dpf, or replacing exhaust? And if so, turbo back or cat back?
Let us know how you like it
Old Jan 5, 2014 | 11:07 PM
9228.bobcat's Avatar
9228.bobcat
Thanks
Oh you'll be getting some hot tunes. Lol. Matt @ gearhead is pretty good. And remember the hotter the tune the better the milage IF you can keep your foot out of it.
Old Jan 5, 2014 | 11:12 PM
reaganla's Avatar
reaganla
Yea what he said
Old Jan 6, 2014 | 10:53 AM
URDADDY's Avatar
URDADDY
Just Dpf delete
Old Jan 6, 2014 | 11:04 AM
URDADDY's Avatar
URDADDY
Figured the tuner would be pretty straight forward was more concerned with the dpf delete pipe. Also can you just disable EGR with tuner or do you have to physically disable it?
Old Jan 6, 2014 | 11:41 AM
reaganla's Avatar
reaganla
Wish I could help ya there... it shouldn't be too bad though. When I deleted my dpf I just straightpiped the whole thing.
Old Jan 6, 2014 | 12:13 PM
9228.bobcat
You can just disable it if you want.
Old Jan 6, 2014 | 07:33 PM
URDADDY's Avatar
URDADDY
If I just disable will it still open and close during idle? Read that somewhere on here.
Old Jan 6, 2014 | 10:06 PM
reaganla's Avatar
reaganla
I was wondering the same thing
Old Jan 7, 2014 | 11:07 PM
URDADDY's Avatar
URDADDY
Maybe somebody knows....
Old Jan 8, 2014 | 12:10 AM
9228.bobcat
If you disable it, its just that disabled. Will not open. It will stay closed unless your boost gets up to like 55 or 60 lbs and under pressure will open it some.
Old Jan 8, 2014 | 12:14 AM
URDADDY's Avatar
URDADDY
Great, that's good to know. Looks like tuner will be here tomorrow as seller promised. The delete pipe on the other hand wont be here when it was supposed to be. But gotta live with it. Will update as I install.
Thanks for the info.
galenfz6
Jun 19, 2012 07:58 PM
TXtinct
May 21, 2012 11:36 AM
mrad
Jul 19, 2011 02:19 PM
c dogg
Jul 7, 2009 07:48 PM
Jzinkiewicz
Jan 7, 2008 06:39 PM
