2002 explorer noises
Old Jun 26, 2003 | 11:50 AM
jasbluesal's Avatar
jasbluesal
My 2002 explorer has a strange noise I think that's coming from the tranny. I have 3,000 miles left under warranty and have brought it to RSM Ford 3 times to fix, but they don't know what is wrong. When the tranny is engaged, it makes more noise. Also, there is a 'chirp' sound that happens every 20 seconds they told me was the air cycling on/off, but it only does it when the tranny is engaged. ???? any other people have similar problems??
Old Jun 26, 2003 | 06:42 PM
RonnieB's Avatar
RonnieB
If it only happens when the trans is in gear, I would suspect the trans pump, or maybe even your FEAD belt is getting cyclic tension/compression pulses and is slipping on your pulleys. What shape is the belt in?
Old Jun 27, 2003 | 11:02 AM
jasbluesal's Avatar
jasbluesal
My explorer has 31,000 miles on it so I would assume the belt would be okay. I had my neighbor Mike w/ Ryan's transmission listen to it last night and he seemed to think the torque converter?? was about to fall apart. Now I have to convince the Ford dealership to fix it while still in warranty....
Old Nov 20, 2003 | 01:08 PM
jasbluesal's Avatar
jasbluesal
It was the torque converter (they replaced at 34,000) now I have 37,000 and my first gear and forward clutches are shot. I HAVE A LEMON!!!!
Old Nov 20, 2003 | 02:20 PM
jhromy's Avatar
jhromy
must be something up with these 2002 explorers...I am currently waiting for a letter telling me my explorer is going to be replaced or not, i went through the dispute board.
Old Nov 20, 2003 | 03:06 PM
jasbluesal's Avatar
jasbluesal
How do I get to the dispute board? Ford Corp is telling me that I'm on my own (out of warranty). You pay $34,000 for a new vehicle so that you don't have to go thru repairs etc., but then you get a LEMON. Frustrating....
Old Nov 20, 2003 | 09:13 PM
jhromy's Avatar
jhromy
look in the back of your owners manual...there will be a number you can call and they send you an application...
