I have a 65 F-100, with a 240 cid. 6. I took off the 1/2" plate & Miller welder and am getting 17.9 to 18.3 mpg. I am wondering : would headers help so I could get even more mpg? Anyone know about this???
Reason: miss spelled : getting
I'd love to get 17.9 mpg. What 1/2" plate did you remove to get that kind of mileage? Also, what trans and rear-end are you running?
I used to do portable welding, the plate was bolted down to the chassis. The welder was bolted to the plate. I run 16" rims, I have Michelin radial tires a granny low 4 speed... the rear end ratio I am not sure of. The biggest thing is to take off from dead stops real easy. I also watch the lights ahead of me and put her in neutral and coast. Soooo... do you know: would headers help me? Where are you, what do you drive?
I had headers and an Offy 4bbl intake and Holley 390cfm carb and a nice cam and best ever was a tad over 16,,, 16.5-16.8, but I also had 4.10's~,,, you have to find the balance of rpm and torque, to low rpms and your engine is working to hard, mileage sucks. On my 66 F100 I have now, I have a 240/1bbl all stock and 3.70's and a T18 and avg. 16.8-17 on the flats,,, you might notice an increase from headers, they are cheap enough to try it out.
Hi, ty for your input. True the headers are reasonably priced. Then the mufflers, 2&1/2 pipes, gskt, probably $350-400. total investment. Do you know if the starter can be changed without having to take off the headers?
On mine it couldn't, I wrapped my headers before I put them on, never had a problem with the starter,,,
I would go with the late model 300 split exhaust manifolds. They are not very expensive when you can find them and will last forever.
Hi Shadowrider, thank you for your great suggestion about the split exhaust mnflds. I went to Geek Parts in N.J., I put in 1995 F-150(as per your saying late model), they called it (the engine) a 4.9, ( I do NOT like the foreign form of measuring) is this a 300 like you said? You are right on. They are cheaper than the headers. Looks like I can change the starter and leave the exh. system intact. WAAY COOL. Also obtain my objective: better mileage.
Sounds like you're trying to squeeze blood out of a rock. Good luck with that! lol
I always find a way. My father had a 1960 VW. It got great mileage, when gas was 17.9 per gal. After the car got some age on it, a hole developed in the muffler. He always checked to see how the car was doing for mpg. With the only change to the car (the hole in muffler) the mpg went up!!! So knowing this, I want to help my engine "breathe" better. I will let you know how it works out. I will be taking my time to get everything done. It may be a coupla months or so. Happy New Year!
Install headers and exhaust on because you want to, not to save mpg.
I doubt that you'll see a 1/2 mpg increase, but lets say you did. Roughly speaking.. $350 is 100 gallons of gasoline. Going from 18mpg to 18.5 mpg, it'll take 66,000 miles to save that 100 gallons.
66000/18 = 3666 gallons
66000/18.5 = 3567 gallons... 99 gallons less than 18mpg.
LOL Don't you hate reality? Where were/are you in the diesel vs. gas debates? Logic seems to be overlooked often in those wars.
If you use the split manifolds with true duals, I would not go bigger than 2 inch pipes...remember there are 2. If you Y them together you could run a single 2 1/4 or 2 1/2".
Great suggestions, thank you. I think the split exh.mnflds are the most practical. The whole point of changing the original restricting stock exh. mnfld is so the engine can "breathe" and then preform to its max. ability. I bet Ford came up with the split mnfld so as to reduce the back pressure/ increase the engines mpg. I was in Choteau Montana in June/ JULY 1976. Nice country you live in. Course I should be there now. Good luck On your COE.
Good Call!! They were on my 79 so I duh... didn't even think about them.
And the heads are the really restrictive part, when I was rebuilding my first 300, my machine shop guy loved the 300, and hooked me up, he did a little porting, and polishing, cleaned up intake and exhaust and matched the headers to the head, (forget what it is called, brain fart) and then he had a grind he really liked for the cam, and he balanced the rotating assembly, I rolled her up to 5500 a few times to whup a rice burner or two but then she would always poop the dipstick out... I have heard of them taking V8 heads and adapting them to the I6,,, but that is a few more bucks than I want to spend!
All in all, you should be pleased with what you are getting! Yer not gonna eeeek much more out of a brick!
