Sponsored by: Real Truck
Brakes applying themselves
Old Jan 4, 2014 | 11:00 PM
Santa 1's Avatar
Santa 1
Here's a new one. Driving along the other day and the back starts hopping. Stop to check and I notice that the rear brake is hot. Stop and wait for it to cool down and then look at the rear calliper, give a wiggle and it is free again. It then drove fine for a couple of days and then today, whilst driving down the road it starts to hop again. Stop and the same hub is hot. Only a mile home so drove slowly back to check it out. Thinking it is some muck got into it causing it to stick. (Living in the Rockies, lots of sand on the road at the moment to deal with all the snow.)
When I get home found that front left wheel is cool but all other 3 are HOT!!
The hopping started on a long flat stretch and I hadn't applied the brakes. Is it possible for the ABS sensor to apply the brakes when you are not using the pedal or is there another reason for 3 wheels to start braking?
Old Jan 5, 2014 | 07:52 AM
Quad Racer's Avatar
Quad Racer
Its somewhat common with these trucks that the calipers will seize.
Old Jan 5, 2014 | 08:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
^^^ yup^^^
i have replaced 2 calipers on my 02 and 4 on my 04.
the 04 does a lot of sitting, the 02 is used almost every day.
i have found sitting is not good for the calipers.
Old Jan 5, 2014 | 08:28 AM
Tom's Avatar
Tom
Your post wasn't clear, so I have to ask. Was the caliper that was sticking the first time also hot when you found 3 of them sticking? Or was that the cool one?
I agree with Tom and Jason, sounds like you have a sticky caliper.
Old Jan 5, 2014 | 12:57 PM
Santa 1's Avatar
Santa 1
First time the rear calliper was hot and after a wiggle it was free. What I didn't check that time was if the other 2 were hot. I have experienced 1 sticky calliper before with other vehicles but not 3, so didn't think to check. It drove all week without any signs of reoccurrence until yesturday. The only reason I noticed that the other side was hot was because I had driven through some deep snow and my wheels were shiney on the 3 which were hot where as the cold one was covered in road salt. I have had sticky callipers before and not known them to "free up" without cleaning especially as my commute to work includes some steep mountains and I use the brakes so they are being cycled. I seems strange that they would all be fine under heavy use, but then when driving along a flat straight section they would suddenly start binding? That is why I thought of the ABS thinking that the "cold wheel" had locked up and it was trying to compensate with the other 3. The only thing with that idea was that you didn't get the usual judder like you do when ABS is activated but just the hopping as the drive train tried to fight the brakes.
Old Jan 5, 2014 | 01:12 PM
BOvice's Avatar
BOvice
I had a similar issue on my 02. ABS light was on and I stupidly ignored it. but the yes the ABS can applie brakes without pedal pressure. My passenger side tire rubbed through my abs line and caused a sieze. Ended up replacing sensor and hub.
Old Jan 5, 2014 | 01:23 PM
Santa 1's Avatar
Santa 1
Just been out to look at the brakes. They're all lose! Took it for a drive and did a neutral free wheel test and it just rolled. Did some heavy braking to engage the ABS and got the judder through the brake pedal (a bit of fun on icy roads at -14C). Came home and all disks cool enough to touch. Must be some electrical glitch?
Snowseeker's Avatar
Snowseeker
Might be possible the pins are getting rusty and binding up. If it were mine I would pull the caliper, drain it and push the pistons back in, clean and grease pins, and reinstall.
Old Jan 6, 2014 | 03:46 PM
jesse5's Avatar
jesse5
Replace the brake fluid, it may have too much water content. Be sure it is not overfull.
Old Jan 7, 2014 | 10:56 PM
Santa 1's Avatar
Santa 1
Had to pull front end apart for another problem, so have checked the fronts. The brakes were all changed 6 months ago. All the pins we cleaned and regreased at this time. Took the fronts apart to check them and they were still good. As I had them apart, cleaned them up again and regreased. Will get to the back ones soon as I get a chance. The brakes have been fine again for the last couple of days.
Old Jan 8, 2014 | 07:31 AM
Snowseeker's Avatar
Snowseeker
Another thing to think about is the rubber lines collapsing/falling apart on the inside.
It will act like a sticking caliper and have much of the same symptoms you are having.
mayor
May 12, 2013 12:43 PM
dockrocker
Aug 26, 2012 09:43 AM
Moto52
Jul 26, 2009 08:49 PM
tinneric
26
May 4, 2006 10:17 PM
tombob
1978 - 1996 Big Bronco
Jun 25, 2005 11:20 AM
