Help no WTS light !
Old Jan 4, 2014 | 04:47 PM
Tailgate77478's Avatar
Tailgate77478
Check to make sure you have enough ATF in your power steering pump reservoir (yes, it takes ATF tranny fluid). If it is low or going bad, when you depress the brakes it will cause a buzzing/whirring sound, even if just sitting at a light. Also check your brake fluid reservoir level.
Old Jan 4, 2014 | 04:49 PM
Blh4488's Avatar
Blh4488
Truck was sputtering. It has stopped. Maybe from changing the fuel filter. Brakes are buzzing and now it sounds like my Power steering is acting up, brakes are only buzzing as I'm about to stop and that's when the PS issue arises as well.
Old Jan 4, 2014 | 05:13 PM
Blh4488's Avatar
Blh4488
Thank you for the help Tailgate. I'll give it a look. Sounds like that'll be my problem. But it's an easy fix so I'll take it!
Old Jan 4, 2014 | 05:33 PM
carltonwebb's Avatar
carltonwebb
Just to throw this out there, it it possible when u checked the fuses this morning, u put one back in the wrong place for something like the abs
Old Jan 4, 2014 | 07:01 PM
dn29626's Avatar
dn29626
Did you replace the #30 fuse or switch it with another fuse?
When the weather is good, disconnect the heater inside the bowl & reattach the wires outside the bowl. that gives a neater appearance.
Old Jan 4, 2014 | 08:07 PM
Blh4488's Avatar
Blh4488
I replaced it w/ a new one. I plan on putting a new heater in not to long from now. Thanks for all the great advice.
Old Jan 4, 2014 | 08:41 PM
dn29626's Avatar
dn29626
A new heater is a waste of money, but it is your money.
Ryan313
Feb 28, 2017 08:45 PM
magicsac1366
Jan 8, 2014 04:57 PM
Richard Olshefski
Apr 9, 2013 09:38 PM
twarrior
Oct 12, 2012 03:47 PM
speedbanger90
Dec 31, 2011 07:10 PM
