Anyone know ABS error codes? please help 97 EX
Old Jan 4, 2014 | 09:36 AM
bigcrunch's Avatar
bigcrunch
1997 Explorer V8 AWD Codes I have
C1185 ABS power relay output circuit fail
C1102 Acceleration Switch Malfunction, may not apply to AWD
B1318 low battery prob had that issue sometime in its life, currently bat is 12.4 and 14.3 runnning.
And ABS light is on.
Old Jan 4, 2014 | 05:45 PM
shorod's Avatar
shorod
Per the factory service manual:
Pinpoint Test B — DTC C1185
NOTE: DTC C1185 is generated when the anti-lock brake control module (2B373) detects an open or ground short on circuits 537 (T/Y), 599 (PK/LG) or 532 (O/Y).
Pinpoint Test M — Code C1102
NOTE: DTC C1102 is generated when the anti-lock electronic control module detects a circuit failure between the anti-lock electronic control module and the G-switch, a damaged G-switch or a damaged anti-lock electronic control module.
If you'd like a PDF excerpt of the troubleshooting section for these pinpoint tests, send me a Private Message with the request, the model year, and an e-mail address for you. The Pinpoint tests reference a breakout box, but you should be able to go straight off of the identified circuit numbers and the connector at the ABS module. Unless of course you happen to have access to the breakout box....
-Rod
Old Jul 12, 2020 | 08:49 AM
Leonardo Fabio Silva Vega's Avatar
[CITA = shorod; 13915156] Según el manual de servicio de fábrica:
Prueba precisa B - DTC C1185
NOTA: El DTC C1185 se genera cuando el módulo de control del freno antibloqueo (2B373) detecta un circuito abierto o corto a tierra en los circuitos 537 (T / Y) , 599 (PK / LG) o 532 (O / Y).
Pinpoint Test M - Código C1102
NOTA: DTC C1102 se genera cuando el módulo de control electrónico antibloqueo detecta una falla en el circuito entre el módulo de control electrónico antibloqueo y el interruptor G, un interruptor G dañado o un dispositivo electrónico antibloqueo dañado módulo de control.
Si desea un extracto en PDF de la sección de solución de problemas para estas pruebas precisas, envíeme un mensaje privado con la solicitud, el año del modelo y una dirección de correo electrónico para usted. Las pruebas Pinpoint hacen referencia a una caja de conexiones, pero debería poder ir directamente de los números de circuito identificados y el conector en el módulo ABS. A menos que, por supuesto, tenga acceso a la caja de
conexiones .... -Rod [/ QUOTE]
Hola buenos días.
Todavía tiene los PDF disponible para las pruebas para el código c1102
Gracias desde colombia
lesilve@yahoo.com
wiredgeorge
May 19, 2019 06:47 PM
7.5GasHog
32
Mar 5, 2018 03:45 PM
rockbust
Mar 5, 2017 01:06 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
98 4.6 locked up
1997 - 2003 F150
Sep 14, 2004 12:34 AM
