I Have A 2013 F250 Deleted, Egr Is UnpluggeD, Is IT Normal For This Engine To Take Forever To Heat UpThe Outside Temp Is Usually 32 And Below, I Don't Drive It Wtfo.Anyone Else Have This Come To Mind.
idling will only get you to 130-140 degrees on my truck and it really doesn't start making heat until it gets to 160 degrees. You likely don't have the supplemental heat options from what it sounds. I do and love it, but I'm just pointing that out if someone says that they get heat faster than you do (so you would know why). If the driving time isn't at least 20 minutes with some decent RPM's this is normal. If you are driving longer than that and still no heat, then maybe something is wrong.
you are wasting a bunch of fuel letting idle for 30 minutes. Start it, let it warm for 2-3 minutes then drive off slowly.
You will get heat sooner and save on fuel.
As long as you don't romp on it when cold there is no harm. Maybe even better for the motor.
Only problem with that when its 5 degrees out is the windshield fogs over completely.Atleast mine does.So I let it warm just enough to get past that point and drive off.
Im NoT Real Worried About Fuel... Im Not A Hand ScrapeR Kinda Person. Ill Sacrifice it.I Don't Never "Romp It" Cold. My H&S Stays On Stock.I Know It Ain't GOnna Heat Up At Idle. Just My 7.3 Was Warm By Time I Got home.
Do you have the supplemental heating option? It's not much for heat, but it will defrost the windows real quick.
In those temperatures, 30 minutes of driving may not be enough to reach full operating temp. As far as heat goes, my truck with the supplemental produces heat fairly quick but my brother's truck without it seems to take forever. It is hard to thaw one of these trucks out since they don't build much heat sitting around idling. Find something to block more than 50% of your radiator off with and that will help.
