I added the T5 to my flatty powered truck and really like it. I retained the stock pedals so keeping part of the original cross member was necessary. I made a heavy duty bolt in cross member for the trans. Using the S10 trans puts the shifter about 6-8 inches rearward of the stock 4 speed location.
Ok, so I feel like a dumb @ss. It turns out the transmission crossmember is cut and there was enough of the crossmember left to support the pedal assembly and master. I posted pics on my album. Luckily I found someone here who has an original crossmember available... call me crazy but I am set on installing an original crossmember. Also found someone who installed a 302/C4 without cutting out the flatty motor mounts/arms. Just an update.
If you just want better highway speed the least expensive option is a ring and pinion change in the Dana 44, you may also have to change the carrier if you chose 3.73 gears or lower, like a 3.08. You can also convert it to a Posi why you are at it. Why it is apart you can repalce all your bearing and seals, it will be like new. Only $500 if you only do the ring, pinion and carrier assuming you do the work yourself. Then if you want to go the Flathead route, spend your money on one of those blown Flatheads from H&H! (my next truck!)
Randys Ring and Pinion is who I used, but there are others. I even found a local shop here who could get the ring, pinion and carrier parts.
There seems to be a big misconception that the Dana 44 gears can not be changed. I have a Ford Racing 302 (306 ci, 340hp and 350tq) with my orginal Dana 44 converted to a posi and beat on it occasionally with no issues. Originally I was going to spend 3.5K on a new complete Moser rear, I saved on the budget reusing my Dana 44 and am happy.
Definitely something to consider, I really hadn't even thought of that option. Now I believe my 49 has a Dana 41? I would imagine the same applies and I would be able to locate the ring, pinion and carrier. I was considering a 9" rearend form a 67-72 F100 but had concerns about having to rebuild it, depending on the condition. So your suggestion might be better since either way I would be rebuilding it. It also goes with my goal of keeping it as original as I can.
I've been in contact with H&H already but might go with Evans Speed Equipment in El Monte. $$$$
I'll let the experts chime in here but I hate to tell ya that the Dana 41 doesn't have the options you are looking for like the 44 does. Pretty much what you have in that rear end is what you have. I've already been down that road with no luck. Sorry.
So did you keep your Dana 41? If not, what did you swap it with? And what motor/tranny are you running?
Is your D41 a 3.73 ratio (standard fitment) or a 4.27 (optional)? If you look at where you are with a 3.73, with reasonably tall tires, you won't gain much by swapping rear end gears. With the C4 you "could" go 3.25 in the rear, and be very comfortable cruising, not real peppy with a flathead tho. More common is 3.50, which is peppier and not bad on the freeway (about 2300 RPM at 55). A flathead will do fine at that RPM. Going to a 3.50 is at least $500 and only gains you maybe 200 RPM.
It's real hard to adjust to the RPM's these older vehicles turned when you are used to modern V8's that are geared way down for fuel economy. No one thought a thing about driving Mustangs, Camaros, etc with 14" tires and 3.50 gears with non-OD trannies back in the '60's. You won't likely get 200K miles out of any engine spinning them that way, that really isn't a concern for hobby trucks.
Honestly I dont know which ratio I have as I just started tearing the truck down and thats how I found out the trans crossmember had been cut. I will find out in the next week or two. Since I will be driving it as weekend vehicle Im not too concerned with fuel economy but do want a bit a pep in it. I wil update the thread once I find out the ratio and if its truly a Dana 41.
NICE!!! I got a 3 sp laying around (in parts that is) and originally thought of rebuilding but I have a C4 in great working condition I took out of my 71 F100. Trying to keep my cost down to rebuild the Flathead.
Just an update: I was able to locate an original transmission crossmember. I have a pic of it in my album if you are curious. Im still planning to stick with C4 transmission and flatty.
Reason: Adding pic link
"Also found someone who installed a 302/C4 without cutting out the flatty motor mounts/arms. Just an update."
When I got my truck, it had a 289/C4 with the original motor mounts in place as well as an uncut trans crossmember. I ended up taking out the motor mounts as the oil filter on the 289 was really close and I wasn't planning on going back to a flathead.
I kept the crossmember original but welded in a flat plate to the rear for the C4 mount.
Would you happen to have a pic of the plate for the C4? I figured it should be fairly simple to fab one up but its always good to see one already in place.
