no start trouble
Old Jan 2, 2014 | 07:38 PM
Bftford's Avatar
Bftford
no start trouble
so about a month ago my truck was warming up in the driveway and suddenly just died. Didn't sputter or nothing just dead. Carb is getting fuel but there is no spark. Coil was tested and is good dizzy is new and I replaced the icm but still won't even pop like it wants to start. I tried to cross the coil plug wire on the battery (pos to neg ) and it didn't spark at all. Thinking maybe coil wire is shot but I've never heard that ever happening . Also directly under the rotor on the distributor the shaft looks like it was welded dead center between the two arms that expand when the rpms increase. Just fried like the distributor was arcing all the way around the rotor . Any ideas ? I love the truck but if it isn't gonna run I can't use it so it'll be craigs listed and I don't wana do that I'll try to post a pic if the roasted distributor shaft. The rest of the " guts" to the pick up and reluctor and such look fine any help would be appreciated
Bftford's Avatar
Bftford
the truck is a 76 with the 360
Old Jan 3, 2014 | 10:30 AM
DutchmanAZ's Avatar
DutchmanAZ
You can run a continuity test on the coil wire easily enough if you have a volt meter.
I assume the engine turns over when you attempt to start it? How have you tested for spark?
DutchmanAZ's Avatar
DutchmanAZ
Old Jan 3, 2014 | 10:20 PM
ColtonMullis's Avatar
ColtonMullis
Your resistor in your positive coil wire could have went out. Are you ruining stock ignition?
Old Jan 5, 2014 | 02:53 PM
Bftford's Avatar
Bftford
yes I have tested for spark and there is none and had the coil tested it works great . Also tested the sires to the coil and there is power. All the way to the coil just doesn't seem like there is any power coming for the distributor. I think I may have fried the pickup in the distributor because after removing the rotor there is evedence that the cap was arching around the rotor to the actual distributor shaft (melted metal and slag on the shaft looks poorly welded)
Old Jan 5, 2014 | 02:55 PM
Bftford's Avatar
Bftford
oh and no the system is after market high performance not stock
Old Jan 5, 2014 | 04:18 PM
ColtonMullis
Well even if you did fry the pickup you would still have about 9v going to the coil. Put your multi meter or testlight on the positive and ground the test light somewhere on the block. When the key is in the run position you should be getting between 6-9 volts. When your starter is running you should get as much that is in your battery. Tell me you're results.
Old Jan 5, 2014 | 04:19 PM
ColtonMullis
You should have full 12 volts then. Sorry didn't read the last comment.
nostartnospark
Oct 1, 2016 09:33 PM
Binkowski
Jun 30, 2014 03:53 PM
drewduncan15
May 21, 2013 02:25 AM
tn.jed
May 6, 2010 06:29 PM
F250racer
13
Jun 18, 2008 08:09 AM
