Loud clunk on start up
Old 01-02-2014, 06:30 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Hey guys - I have a 06-E-350-5.4 l - with about 55k on it. I am getting a very loud clunk (feels like floorboard area) on cold starts only occasionally- I have been doing a little research & am thinking - broken timing chain guide as it only does it maybe every 5th time I start it, always on cold start up in morning it also ticks for about 15 seconds when cold.Also could this be a bad starter.Should I replace starter & see how it does?I am aware of the oil & filter issues with these engines & I found out the hard way about using the filter with the anti drain back valve. Any help much appreciated.
__________________
Old 01-10-2014, 06:18 AM
jesse5's Avatar
jesse5
jesse5 is offline
Your suspicion on the timing set is probably correct. The dog-box in a van will make the sound different than on a pickup. I would check the crankshaft thrust anyway with a pry bar and dial indicator.
Old 01-11-2014, 04:56 PM
guitarpicr's Avatar
guitarpicr
Jesse - I am gonna check the plugs & make sure they are all tight, but I think the loud noise is the timing chain or tensioner. Thanks for your input
BCHauler
1997 - 2003 F150
03-25-2014 06:12 PM
guitarpicr
01-02-2014 06:11 PM
weevensteven
Modular V8 (4.6L, 5.4L)
04-01-2012 09:23 PM
amer28
01-16-2011 01:17 PM
Spectramac
01-09-2004 11:42 AM
Quick Reply: Loud clunk on start up
